need help... D16Y >> B18C Swap
Old Jan 16, 2003 | 01:49 AM
tuned.in's Avatar
Default need help... D16Y >> B18C Swap
Hi
i want to do the D16Y to B18C5 swap for my 97 EK Civic
The most I've done on an engine apart from simple DIY servicing is a water pump replacement.
Before I consider doing it myself I would like to see exactly what ill be up for.
I need direction on where to start. I've done research but i can tell from that there is more ill need to know.
I require the knowledge and experience from people in these forums that have performed such work for help.
Other threads, books and webs where i can find comprehensive info on for doing the swap is what I guess I need...
Any help appreciated...
Old Jan 16, 2003 | 04:59 AM
sohc_boy's Avatar
Default Re: need help... D16Y >> B18C Swap (tuned.in)
go to this site there should be some pretty detailed info to help u out. http://hybrid.honda-perf.org/
Old Jan 16, 2003 | 05:00 AM
sohc_boy's Avatar
Default Re: need help... D16Y >> B18C Swap (sohc_boy)
here is the exact link to the info on there site http://tech.hybridgarage.com/tech/6gtech/index.html
Old Jan 16, 2003 | 06:19 AM
tuned.in's Avatar
yeah i came across them in my searches
Guess I'll have to buy the Helms manuls
Old Jan 16, 2003 | 07:25 AM
sohc_boy's Avatar
what exactly do u want to know, its pretty much a plug and play job. the only thing u should have to buy is the rear mount. u can just add a few wires to your harness. get an ecu from a 96-99 gsr and it will just plug in.
smooth95
Aug 18, 2006 08:18 PM
SI_SOLDIER
Nov 12, 2003 05:50 PM
eg6hatch
Jun 10, 2003 10:04 PM
Peter K
Mar 17, 2003 10:05 PM
