Integra Front Brakes!!!
Old Jan 15, 2003 | 10:06 PM
civicdragger818's Avatar
Default Integra Front Brakes!!!
I just bought a set of integra front brakes for 20 bucks with turned rotors and new brake pads from a friend. What all is involved in puting them on my car???? How hard is the work??? I have a 88' DX with a b18a in it. I had another friend that did this but I havent talked to him in a while. So any info you can give would be nice. Oh yea and I did search......
Old Jan 15, 2003 | 11:44 PM
philly-O's Avatar
Default Re: Integra Front Brakes!!! (civicdragger818)
what is included with the "brakes"? does that include just the rotors and pads? or the whole assembly?
Old Jan 16, 2003 | 12:20 AM
thaiphob's Avatar
Nikon!!!
did u just buy the breaks or the whole knuckle/hub assembly?? if u just bought the breaks you got a lot of work ahead of you. if you got the hole assembly then the swap should be very easy, just time consuming.
Old Jan 16, 2003 | 06:16 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Integra Front Brakes!!! (thaiphob)
I will be selling my integra front disc brake assembly pretty soon.
I am running 13x9 bogars so i wont be able to use them.
Integra knuckles, brakes, calipers, rotors, all for sale real soon. Selling because
I have the 99 integra knuckle, hubs wtih STuds for my bogarts and i will be using 92-95 civic brakes and calipers.
Old Jan 16, 2003 | 08:35 AM
Its the whole assembly. I made sure of this.
Old Jan 16, 2003 | 11:31 AM
zCivic's Avatar
Well if thats the case. You need to disconnect the 3 ball joints, remove the front axles, take the brake lines off at the top where it goes back to being the metal lines and replace it all back with the Integra in reverse. Bleed your brakes. You have a DX/SI correct if not (HF/STD) you will need different axles from a DX/SI. hope this helps
Old Jan 16, 2003 | 12:24 PM
Chris's Avatar
Default Re: Integra Front Brakes!!! (zCivic)
I also have a complete DA front setup for sale.
See sig.
Old Jan 16, 2003 | 02:11 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
dont forget the alignment!!!!!!!!!!!!!!
carbonlaced
Suspension & Brakes
Sep 8, 2006 09:25 AM
94CIV
16
Apr 7, 2005 09:53 AM
sleeping beauty
Apr 7, 2004 05:13 PM
VitaminB20
Nov 9, 2002 06:15 PM
93SSPHatch
May 15, 2002 05:17 AM
