90 crx w/b18a.....when temperature drops below 30 degrees; car won't stay on....any suggestions
Old Jan 15, 2003 | 07:31 PM
cliffjumpercrx's Avatar
Default 90 crx w/b18a.....when temperature drops below 30 degrees; car won't stay on....any suggestions
Wassup everyone,
Question: I have a 90 crx hf with a b18a swap. I was running a PM6 ecu, and whenever the outside temperature would drop below 30 degrees my car would start up, engine light come on, and then shut off in the morning. I would force it to rev at 3,000 rpm for a couple of minutes then it would stay on by itself. Then once the car was warmed up, I would shut it off, and restart it.........no engine light would come on for the rest of the day. Unless it sat for several hours.
K......I get a 90-91 PR4 ecu, and swap it in. Now whenever it has been under 30 degrees, and the car has sat off for several hours, upon start-up, the engine light comes on, but the car stays on, and warms up and idles normally. After warming up, I restart and the light stays off.
Whenever the temperature is over 35 degrees the engine light never comes on.
So this is my problem ..........can any of you guys relate, and does anyone have an answer......Thanks
Old Jan 15, 2003 | 09:31 PM
giooooo's Avatar
Default Re: 90 crx w/b18a.....when temperature drops below 30 degrees; car won't stay on....any suggestions
yo i have the same thing with my integra ... it only acts weird during cold weather .. but i dunno why it does this...
[Modified by Giovannie, 6:32 AM 1/16/2003]
Old Jan 15, 2003 | 09:48 PM
yeah my last few cars were DA tegs...they did this too.......maybe someone can give us some info...the motor I have now came out of a 92 teg
Old Jan 16, 2003 | 03:22 AM
Sirex's Avatar
the ecu probably froze, my 2001 vw gti 1.8t would do that if i turn it on it idles at 1500 rpm and if i even dare touch the throttle it starts choaking and turns on i have to let it hit 900rpm idle then i can slowly take off.. once the car is warm its fine... and if i take off at 900rpm but the needle is still saying cold i get like 5psi of boost rather than my 1.1 program (15psi), my ecu sits like in the engine bay which is of course outside the car im sure the chips are frozen and electronics have a hard time functioning correctly is freezing or scortching hot temps...
stupid vwdub.
Old Jan 16, 2003 | 04:11 AM
Patch's Avatar
Maybe its the coolant temperature sensor? When I had my Jeep, if it was really cold outside I could make it to then end of the block and it would cut off.
Old Apr 30, 2005 | 10:13 PM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cliffjumpercrx &raquo;</TD></TR><TR><TD CLASS="quote">Wassup everyone,
haha...cool I found my old name...I finally guessed right after searching a few times...I disappeared shortly after making this post (2 weeks) cause somebody stole my rex
and I had no money to get into a honda for almost a year, not to mention I was so pissed off I didn't want to even look at another honda, so I took a break, and when I came back I forgot my name and password.
anyway
but I had figured out the problem, I had a bad ecu, it was a pm6 ecu running a b18a swap, and it was faulty on top of that.
I found a pr4 ecu, but it didn't plug in cause it was an obdI pr4 (92-93 integra)
a couple days later I was able to pick up a obd0 pr4 (90-91 integra) and it pluged right in.
I also fixed the mounting of the swap with hasport efb1 billet mounts that had just come out and a hasport shift linkage.
then one week later it was stolen
pics of the motor:
Old Apr 30, 2005 | 10:19 PM
folta2169's Avatar
where is the coolant temp. sensor located on the motor, and how much is a new one. i also have trouble starting the car up when it is cold.
Old May 1, 2005 | 12:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by folta2169 &raquo;</TD></TR><TR><TD CLASS="quote">where is the coolant temp. sensor located on the motor, and how much is a new one. i also have trouble starting the car up when it is cold.</TD></TR></TABLE>
the engine coolant temperature sensor (ECT) I belive is located on the thermostat housing or right in that area of the motor if I remember correctly...but that was on a b18a/b motor...wish I had pics or a diagram
Old Jun 19, 2005 | 11:51 PM
sike's Avatar
the collant temp sesor is located JUST under the distributor, i had to take the whole damn thing off to get to mine...
Old Jun 20, 2005 | 03:48 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sike &raquo;</TD></TR><TR><TD CLASS="quote">the collant temp sesor is located JUST under the distributor, i had to take the whole damn thing off to get to mine... </TD></TR></TABLE>
Also, don't confuse the ECT for the temperature gauge sender. The temperature gauge sender has only one wire connected to it. But The ECT has a plug with two wires.
Jeremiah Rich
Jul 4, 2016 08:33 AM
Tysnet
Sep 19, 2012 09:05 PM
EKcivicEK
Jul 17, 2010 09:45 PM
B18C1 Civic EG
Feb 8, 2005 07:56 PM
cliffjumpercrx
Jan 14, 2003 09:01 PM
