Fuel Pump which is a good fuel pump/reg/filter?
Old Jan 15, 2003 | 06:44 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Fuel Pump which is a good fuel pump/reg/filter?
I will be driving my car on the strees once in a while
fully built engine, t4 turbo
venom fuel rail
96lb injectors
t4 60-1 turbo
which is a good fuel pump for the $$ and filter and reg?
Aeromotive
Paxton
etc...
name some and prices
I think jason was using a walboro not sure. which he can help out. since im also using acrx.
Old Jan 15, 2003 | 09:26 PM
turbohonda's Avatar
Default Re: Fuel Pump which is a good fuel pump/reg/filter? (Civicdrgrcr)
The Aeromotive and the Paxton are the same pumps. Paxton just puts their name on them. The Aeromotive pumps and regulators work pretty well especially if you drive them on the street. Just stay away from the SX pumps and regulators, I have had bad experiences with them. The Weldon's are nice to but can't be street driven.
Old Jan 15, 2003 | 09:59 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Fuel Pump which is a good fuel pump/reg/filter? (turbohonda)
i have an aeromotive pump and its is workign fine so far. weldons are big dollars. like over 1000.00 with regulator.
by the way what problems have you had with the sx? my friend just got the red oen that looks like the aeromotive. its for gas and alcohol.
Old Jan 15, 2003 | 10:11 PM
turbohonda's Avatar
Default Re: Fuel Pump which is a good fuel pump/reg/filter? (MotorMatrix.com)
My SX pump came apart internally and lost flow but didn't shut off. Since it didn't shut off completly it cost me an entire motor (25psi of boost and low fuel pressure don't mix ). A few months later I got the Aeromotive Eliminator pump with my -6 SX regulator. I started having a fuel pressure spiking problem. I was told that the seat that the spring loaded regulator ball sits on gets messed up. When I took it apart, sure enough the ball had sunk into the seat and it was now oblong. I am not sure I just had bad luck with both of them but I would never buy another SX part again. Alot of racers use SX parts and don't seem to have a problem, so who knows.
Old Jan 15, 2003 | 11:28 PM
rice a rona's Avatar
I use a sx pump with no problems. I also though areomotive was a divison of SX?
Old Jan 16, 2003 | 06:07 AM
Default Re: Fuel Pump which is a good fuel pump/reg/filter? (top notch)
So aeromotive is my winner i suppose.
Old Jan 16, 2003 | 01:21 PM
StageIIIhb98's Avatar
I use the holly 255 forced induction fuel pump is this a good or bad it is the intank one on a 98 civic b turbo 440 injectors fuel ral with filter. I run up to 20 psi with a cartec boost fuel riser . I hear everybody talk about those big *** pumps do any of you think I need one
Obama
Texas -OK -LA (Sales)
Oct 28, 2010 12:18 PM
jakem200
Apr 9, 2009 09:53 AM
prestonpark
Mar 15, 2006 09:45 PM
2000_Civic_Si
Feb 8, 2002 04:13 PM
