what year b18?
Old Jan 15, 2003 | 06:29 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default what year b18?
I dont know if you guys read my post a couple day ago about my "mystery engine" or not but ill recap. Well i bought an engine that was supposed to be a 92 b18a. Well i got to thinking about it and realized that i got a PR4 ecu with it...i know that the PR4 comes on the 90-91(non obd), but i dont know if the 92-93(obd1) engines use this ecu also. Well i asked you guys how to tell the difference and i was told that the year is stamped on the side of the head. Well today i went to look at it and i couldnt see the right side of the engine b/c if the timing belt cover...but i did see a few other numbers that might be helpful. On the front of the block it had PR4-4 stamped on it...and it also had a bunch of other letters stamped inside of circles...one was 92. I dont know if this can help me or not so im asking you guys...is this an obd0 or obd1 engine? ANY INPUT WOULD BE APPRECIATED!!!!
Thanks.
Sean
Old Jan 15, 2003 | 06:38 PM
EP3_05's Avatar
Default Re: what year b18? (sCeRaXn)
The 92-93 B18a also came with a PR4 ecu except it was the OBD1 version. From what you are describing it sounds as if you have an obd1 non-vtec b18.
Old Jan 15, 2003 | 07:38 PM
cliffjumpercrx's Avatar
Default Re: what year b18? (91civic)
I have a b18a 92 motor in my rex, and recently went to change the ecu; it was running on a PM6 ecu so I wanted to put in a PR4..............I bought a PR4, but it didn't fit my wire harness plug.............it was a 92-93 PR4, and my wire harness had the plug for the 90-91 ecu's like the PM6 and PR4
that's how I learned there were two PR4 ecu types....one for 90-91 obd0 harnesses and one for 92-93 obd1 harnesses. But it sounds like you have a 92-93 motor.
golf-mk3
Sep 18, 2010 09:43 AM
BROCKMYSTER
May 11, 2010 08:55 PM
clubef9
Oct 4, 2007 07:15 PM
grngsr01
Jun 2, 2004 05:00 AM
jahnericm
Mar 8, 2004 02:39 PM
