d16y7 swap into 89 crx si?
Old Jan 15, 2003 | 06:07 PM
red_honda_racer's Avatar
Default d16y7 swap into 89 crx si?
Maybe someone can help me out. I'm putting a d16y7 w/ hydraulic tranny into a cable ready 89 crx si, I wasn't having any problems untill the ecu wouldn't hook up to the motor harness it came with, only 2 of the plugs of the 3 hook up, I still have the stock ecu for the d16a6 and the original harness. The other problem I have is the shifter linkage, I have both cable and hydraulic but I was wondering if anyone knew of any mods I could do to it instead of going out and buying a new shifter linkage conversion kit. If anyone could help me out with some tips or if anyone has done this swap before please help me out cause I'm kind of on a time limit. Thanx.
Old Jan 15, 2003 | 06:20 PM
altoid's Avatar
Default Re: d16y7 swap into 89 crx si? (red_honda_racer)
well one is non obd (a6) other is obd2 (y7) you'll have to do a full conversion to obd2 or keep your stock ecu and harness...which means you'll also have to keep your a6 dizzy and fuel injectors, though youo may just be able to ditch the resistor box and keep the y7 injectors, but im not sure...since you don't have vtec its not a big deal, some stuff will have to be rewired though if using the y7 harness.
[Modified by altoid, 10:21 PM 1/15/2003]
Old Jan 15, 2003 | 06:24 PM
Default Re: d16y7 swap into 89 crx si? (altoid)
I'm don't mean to sound like a retard but what the hell is a dizzy?
Old Jan 15, 2003 | 06:27 PM
hybridmike's Avatar
easiest way would be to put it in as if was a d16a6 and use the cable trans
Old Jan 15, 2003 | 06:33 PM
Default Re: d16y7 swap into 89 crx si? (hybridmike)
what if I use the a6 harness and ecu and switch the y7 dizzy and injectors with the ones off the a6, would that work, cause I don't want to have to rewire anything.
Infinity_Racer's Avatar
dizzy = distributor...i asked the same question a while back
Old Jan 15, 2003 | 06:48 PM
YumVTEC's Avatar
yes that will work. that's pretty much the best idea to do what you want to. add the d16a6 intake and exhaust manifolds as well as throttlebody to that list and you'll have a bad *** little swap going on.
oh and don't bother using a hydro tranny. the amount of custom work necessary to make this work would be retarded, especially with a SOHC swap. just buy a used 4g Si cable tranny.
Old Jan 15, 2003 | 06:54 PM
Default Re: d16y7 swap into 89 crx si? (YumVTEC)
I have the a6 tranny, will it fit on the y7?
altoid's Avatar
indeed it will
if you want to get fiesty you can just swap internals, and have a cable engaged y7 tranny
[Modified by altoid, 10:55 PM 1/15/2003]
Old Jan 15, 2003 | 07:19 PM
Well I think I gonna swap trannys and intake manifold, throttle body, dizzy, and exhaust manifold from the a6 and put them on the y7. Plus use the a6 ecu and harness, so wish me luck you guys an thanx alot for all your info, its been a great help to me. If you have any more tips to give me please add.
Old Jan 16, 2003 | 07:52 AM
YumVTEC's Avatar
you'll also have to use the a6 alternator, and alternator bracket. the a6 driver side mount bracket and rear tranny bracket. i used the 4g crank pully as well instead of the y7, but i've heard this could cause premature bearing wear because they're not balanced the same. you've got the right idea though...
Old Jan 16, 2003 | 08:16 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
indeed it will
Are you sure about this?
I have the Y7 tranny that came with my engine and that tranny is 100% new.
If the gears, shafts, and all the other guts can be swappd, I'll do that!
Old Jan 16, 2003 | 08:17 AM
Adriano's Avatar
in other words, swap everything that is attached to the block?? right
Old Jan 16, 2003 | 09:04 AM
d15dood's Avatar
you should have had someone else do the swap if you didnt think about obd before you started
Old Jan 17, 2003 | 10:50 AM
Default Re: d16y7 swap into 89 crx si? (jungle)
Everything is almost done, I just have to put the halfshaft in, shifter linkage and tranny fluid and thats it, I had to rewire the y7 alternator to fit the a6 harness, but other then that it will be ready to start up saturday, I'm taking a break today. So I hope everything goes well, I don't doubt my skills.
Old Jan 17, 2003 | 01:59 PM
YumVTEC's Avatar
just use the a6 or any other 88-91 civic alternator... you can rewire, but what a bitch!
Old Jan 18, 2003 | 10:49 PM
Everything worked great, only thing needed is the clutch to be adjusted. Other then that the test drive went great until my buddy drove it and got pulled over because the car doesn't have plates on it or insurance cause we were doing the motor swap for a friend. Thanx a lot you guys for all the help, your the best!!!
neophish
Aug 27, 2013 06:52 PM
dusterbd13
Jul 18, 2009 12:23 PM
89loudcrxsi
Aug 12, 2007 05:19 AM
jscblulu
13
Nov 15, 2004 06:33 PM
civicshowracing65
May 24, 2004 05:25 PM
