someone please help, turn signal fuse!
EDIT: i fixed that ****!!! woo hoo! it was fuse 26, but under the dash, they are numbered up to 23, so there was this white connector that didn't have a fuse in it, so i put one in, and it works!!!!!!!! woo hoo! thanks for all the help guys! for everyone!
[Modified by AH Tow Ex, 2:06 AM 1/16/2003]
Hey man, check all your wiring, if you replaced the fuse and the relay and it still dosnt work then it might be that the wires that go from your fusebox to your switch on your steering wheel and then to the blinkers, just play around with it.
for everyone!
for everyone!
