torque for valve cover nuts?
Old Jan 15, 2003 | 04:10 PM
magic hat #9's Avatar
Default torque for valve cover nuts?
helms mentions 7.2 ft*lbs for cap bolts (or similar), but the diagram seemed off and that sounds awfully light.
does anyone know the torque specs for the valve cover nuts?
fyi, it says the valve adjustment nut should be torqued to 18 ft*lbs.
Old Jan 15, 2003 | 04:14 PM
BlueR's Avatar
Default Re: torque for valve cover nuts? (magic hat #9)
careful, i broke one of those ******* last weekend
and i had a helms manual right next to me
Old Jan 15, 2003 | 04:15 PM
Chris N's Avatar
Don't overtorque those, they will break easily.
I don't have my helms handy right now, but remembering tightening down a friend's valve cover, it was very low.
I remember it being less than 8ft-lbs, so 7.2 sounds right.
Even overtorque-ing a little bit will cause damage.
Old Jan 15, 2003 | 04:20 PM
cheezthis's Avatar
Default Re: torque for valve cover nuts? (Chris N)
...hope that helps.
Old Jan 15, 2003 | 04:25 PM
RockstarJR's Avatar
you tighten those???
Old Jan 15, 2003 | 04:27 PM
TypeR 599's Avatar
Default Re: torque for valve cover nuts? (ITRChris)
"snug" tight them
Old Jan 15, 2003 | 04:36 PM
Hooch'n's Avatar
Default Re: torque for valve cover nuts? (TypeR 599)
yep...snug and done!
Old Jan 15, 2003 | 05:12 PM
Default Re: torque for valve cover nuts? (Hooch at 8400-RPM)
ok, i was reading it correctly then. i will soon have a torque wrench for use in 100in*lbs - 600in*lbs (8.3-50ft*lbs), but even this won't help. no problem, i'll stick with handtight.
Old Jan 15, 2003 | 05:27 PM
MattD@Stoptech's Avatar
When we d0ing my valve adjustment, f00?
Old Jan 15, 2003 | 06:37 PM
GZR4DR's Avatar
Default Re: torque for valve cover nuts? (El Pollo Diablo v3.5)
Just tighten till snug. No need for a torque wrench on that. I only use a torque wrench when putting on a head, cam caps, or doing work on the internals of a block. Everything else is by feel.
Old Jan 15, 2003 | 07:16 PM
don't be lazy, come over thursday. we'll leave your car outside to cool while we have
Old Jan 15, 2003 | 11:07 PM
Phoenix_ITR's Avatar
Default Re: torque for valve cover nuts? (GZR4DR)
i actually think a couple of those studs may be stripped -- how would i go about repairing that? thanks in advance...
-tony
Old Jan 15, 2003 | 11:11 PM
b19coupe's Avatar
Default Re: torque for valve cover nuts? (delinquent)
Pull the valve cover and replace the studs. Torque the studs to 19 ft/lbs.
Old Jan 15, 2003 | 11:12 PM
Default Re: torque for valve cover nuts? (b19coupe)
would it most likely be the studs that are stripped? or could it be the head itself?
B2FiNiTY's Avatar
Studs
Old Jan 15, 2003 | 11:46 PM
Default Re: torque for valve cover nuts? (B2FiNiTY)
good...that's what i was hoping
julianbc2
Dec 30, 2008 04:14 PM
delguiner
Aug 16, 2004 11:33 AM
hott-nix
Apr 15, 2004 01:01 PM
vtecsoldseperately
Dec 16, 2002 02:14 PM
1fastGSR
Oct 1, 2001 04:20 PM
