Street/Race Clutch/flywheel setup do you recomand?
Old Jan 15, 2003 | 04:07 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Street/Race Clutch/flywheel setup do you recomand?
I will be driving my car on the street maybe 2-3 times a week.
Mostly a all out car.
t4 turbo, Fully built motor, axles, etc...
WHich clutch/flywheel do you recommand.
Tilton $1400 and its clutch/flywheel?
Any others
Old Jan 15, 2003 | 04:11 PM
tractionbar2nr's Avatar
Default Re: Street/Race Clutch/flywheel setup do you recomand? (Civicdrgrcr)
that is a great clutch. i know exide came out with a new line of twin disc clutchs for hondas this year... you might want to look at some of what they have to offer.
-mike
Jared's Avatar
The tilton is a great setup, be very high for a street car. Seriously consider a cm flywheel or comparable other in weight and the ACT double xtreme pressure plate and 4 puck disc.
Old Jan 15, 2003 | 06:41 PM
Default Re: Street/Race Clutch/flywheel setup do you recomand? (Jared)
I know tilton sells 3 different types of clutches
Street Clutch/flywheel setup
metal to carbon
and carbon to carbon.
How is the clutchmasters twin disc setup it comes wtih flywheel right for aroudn $1200.
My car is a crx so cable tranny. car will be driven on the streets rarely.
Old Jan 15, 2003 | 11:51 PM
MotorMatrix.com's Avatar
I am a bad person
I run the clutchmaster double disc on mine. the pedal is softer than stock it grabs like a bitch. the clutch has held 750whp and never slipped on a buddys car. I have made 565 and it doesnt slip at all. I like it .
Old Jan 16, 2003 | 06:05 AM
Default Re: Street/Race Clutch/flywheel setup do you recomand? (MotorMatrix.com)
HOw much does it run around. It also comes with the flywheel right.
Old Jan 16, 2003 | 07:40 AM
29psiHybrid's Avatar
I have a CM twin kevlar/kevlar. Pedal feel is great, pretty chattery though. I'd rather have a chattery clutch then a hard pedal feel though.
Old Jan 16, 2003 | 07:54 AM
jinxproof99's Avatar
New User
Default Re: Street/Race Clutch/flywheel setup do you recomand? (9psiHybrid)
me and jason both ran the clutchmasters twin disc(kevlar). we both had over 500 to the wheels and it holds all the power and is very streetable, considering a 500 hsp honda is "barely" streetable. the inlinepro race car ran the same exact clutch set up. over 600 to the wheels. never broke for any of us. 100's of passes.
price will depend on where you get it. i got mine for under a 1000 but they retail for more than that. inline is an authorized dealer. call stan.
Old Jan 16, 2003 | 08:42 AM
littlebluecrx's Avatar
Default Re: Street/Race Clutch/flywheel setup do you recomand? (jinxproof99)
Yep, me and Karl ran the twin disc, Inline should stock it for any honda, like matrix , and robie's I loved mine, I am using the same one just swaping discs out too the newer hydro splines. Jason
Old Jan 16, 2003 | 09:45 AM
StageIIIhb98's Avatar
Default Re: Street/Race Clutch/flywheel setup do you recomand? (littlebluecrx)
I am thinking of changeing mine I am running a cm flywheel and extreme ACT pressure plate with 6 puc disk. The pedle is hard as hell but if grabs real real good I guess the only bad this is the peble feel
Old Jan 16, 2003 | 09:57 AM
Does it Come with the flywheel as well?
Old Jan 16, 2003 | 10:02 AM
I am a bad person
all of the double disc setups I believe come with the pressure plate. Atleast i know the clutchmasters and tiltons do. since the whole clutch assembly is smaller in diameter than stock you have to run their pressure plates.
Old Jan 16, 2003 | 10:04 AM
What about the flywheel?
Old Jan 16, 2003 | 10:07 AM
I am a bad person
opps meant flywheel. not pressure plate. but they do also come with pressure pl;ate also. its one complete assembly!!!
Old Jan 16, 2003 | 10:24 AM
I guess im going to end up with a clutchmasters instead of tilton.
Old Jan 16, 2003 | 10:15 PM
FRESH's Avatar
What about ACT? they make a new flywheel now too 220 for the flywheel and 430 or something for any of the clutches.. Ive herd better news of act than clutchmasters.
Old Jan 28, 2003 | 02:12 PM
Default Re: Street/Race Clutch/flywheel setup do you recomand? (FRESH)
ACT is a good clutch but when you start making power in a fwd car, you are going to have to get a twin disc clutch. they can hold more power.
i would say tilton over clutch masters but i do know that clutch masters is way cheaper... its all good because the clutchmasters clutch looks just like the tilton (well almost).
Sicarius82
Jul 2, 2006 06:57 PM
d_mina
Aug 25, 2004 06:28 PM
Unjockable
Nov 17, 2003 04:49 PM
gotnothing
Dec 9, 2002 02:43 PM
willyboyK20
May 1, 2002 01:32 AM
