Question about comperssion ratio?
Old Jan 15, 2003 | 01:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Question about comperssion ratio?
I understand c.r. and the higher the cr the more hp you get, but what i dont understand is the set up of the numbers ex. 10.6.1....... I know this may sound stupid but i would really like to know what all the numbers mean so when someone ask a question ill know the answer for sure.
Old Jan 15, 2003 | 02:23 PM
Quiz's Avatar
Default Re: Question about comperssion ratio? (HybridcivicLS-T)
Lets take a 10 to 1 compression ratio. The 1 is the volume of the combustion chamber at TDC. 10 is the swept volume plus the combustion chamber volume (volume of the complete cylinder at BDC).
Example:
Combustion chamber vol. of 50cc
Complete cylinder vol. of 500cc
Divide 500cc by 50cc = 10 or (10 to 1)
50cc x 10 = 500cc per cylinder
500cc x 4 cylinders = 2000cc x .001 = 2.0L
[Modified by Quiz, 6:34 PM 1/15/2003]
Old Jan 15, 2003 | 02:29 PM
wm5holla's Avatar
i would like 2 know too, thanxs !! this cr has me lost 2
Old Jan 15, 2003 | 02:35 PM
Quiz's Avatar
Default Re: Question about comperssion ratio? (wm5holla)
what did you miss?
Old Jan 15, 2003 | 02:51 PM
wm5holla's Avatar
Default Re: Question about comperssion ratio? (Quiz)
thatinfo wasNOT there wheni posted we have posted at the same time
Old Jan 16, 2003 | 11:53 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Thanks now i know, so if it is 10.5.1 it's basically 10x1=10 and the other number like 4 or 5 we'll say 4 times that 10 ='s 40cc per cylinder. Times 4 so 40x4=160. Then times 160x10=1600cc.................B16, D16, ZC16..Thanks.
Antwaine
Old Jan 16, 2003 | 12:05 PM
Quiz's Avatar
No
This 10.5.1 you give as an example should read 10.5 to 1 c/r
The 50cc and 500cc were just arbitrary numbers I gave you for examples of volume.
If you had a 50cc combustion chamber with 10.5 to 1 c/r then you would have 525cc BDC cylinder volume
525cc x 4 cyl = 2100cc x .001 = 2.1l
Old Jan 16, 2003 | 12:33 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
ok i understand..............10.5 is what i multiple to get the cc's and the 1 is because it's only 1 engine.....lol
Old Jan 16, 2003 | 01:00 PM
Quiz's Avatar
10.5 represents how many times you could fit the volume of 1 combustion chamber (TDC volume) in the complete cylinder volume at BDC
[Modified by Quiz, 5:02 PM 1/16/2003]
blackeg
Jan 19, 2015 05:43 AM
northcb7
Jun 8, 2009 12:31 PM
eg6_kaydoo
May 23, 2008 09:10 AM
disboilikehoy
May 23, 2004 05:41 PM
ATS*Mark
Jan 18, 2004 03:25 PM
