Check engine light on my 89 LXi.
Old Jan 15, 2003 | 11:41 AM
POS's Avatar
POS
Default Check engine light on my 89 LXi.
Hey everyone,
I just picked up an 89 LXi for my winter beater last week. I got it for $50 so it was too good to pass up.
Anyways, the check engine light is on more than its off lately. Is there a way to read the codes without buying a scanner on these cars? I have Mustang and you can just use a jumper wire, but I'm not even sure where to start on these cars.
Also, how many miles to a tank should I expect with this car? Its an auto w/ 172k on it. I've gone 270 so far and the low fuel light hasn't come one yet, just curious if thats about right or not.
Thanks.
Old Jan 15, 2003 | 02:12 PM
Chiovnidca's Avatar
Default Re: Check engine light on my 89 LXi. (POS)
The ECU is mounted on the floor under the drivers seat. Flip down the little door on the back of it, and count the flashes of the LED. (If you push the seat all the way forward, it's easy to get to.)
Old Jan 15, 2003 | 03:18 PM
POS's Avatar
POS
Default Re: Check engine light on my 89 LXi. (Chiovnidca)
Cool. So do I have to do anything to put it in test mode or will it just blink when I look at it? Sorry, I'm new to Hondas.
Also, is there a database to lookup the codes and how do I clear them? Just disconnect the battery.
Thanks.
Old Jan 15, 2003 | 03:46 PM
Chiovnidca's Avatar
Thanks.
You just need the key on. Disconnecting the battery will clear the code.
http://tech.hybridgarage.com/tech/codes.html
Old Jan 15, 2003 | 04:12 PM
POS's Avatar
POS
Thanks man, looks like I've got a code 6. ECT sensor. I'll check it out.
Thanks again for the help.
Old Jan 15, 2003 | 04:16 PM
Chiovnidca's Avatar
Make sure your coolant level isn't low.
Old Jan 15, 2003 | 04:18 PM
POS's Avatar
POS
It shouldn't be, I topped it off Saturday. The car had been sitting for 3 months and it was low when I got it.
The check engine light comes on after the car has been running for a few minutes, so it kinda makes sense about the ECT sensor.
Does it effect gas mileage much?
Old Jan 15, 2003 | 04:36 PM
Chiovnidca's Avatar
It can. If it's telling the ECU the engine is cold, it will run very rich.
Old Jan 15, 2003 | 04:47 PM
POS's Avatar
POS
Well damn, I hate to spend $30 for a part on a car I paid $50 for, but I'll pull it out and see if the connections are dirty or if its corroded.
OMGBBQTEHWTFDOOD
Oct 19, 2007 10:18 AM
89civichb
May 10, 2007 06:42 PM
pec pec
Jan 31, 2006 07:46 PM
DeeperFOLK
Oct 11, 2002 01:36 PM
ex_crxer
Apr 6, 2002 07:54 AM
