h22 question
Old Jan 15, 2003 | 11:40 AM
johnsaccord's Avatar
Default h22 question
I getting a jdm h22 swap for my 97 accord 5sd so I want to stick to obdII. It is a low mileage motor for a good price, but if I go lsd, it will be from an older motor. Should I get the older (more abused) lsd tranny or just stick with the newer non-lsd tranny? I want lsd but don't know if it's worth it since it will be older???
[Modified by johnsaccord, 3:43 PM 1/15/2003]
Old Jan 15, 2003 | 11:45 AM
KGAccord's Avatar
Default Re: h22 question (johnsaccord)
I would use that $300 or so extra for a Honda LSD and save up another $400 for a Quaife LSD. It's much better and when the Honda one breaks you can't fix it.
Old Jan 15, 2003 | 11:47 AM
Nick M's Avatar
Default Re: h22 question (KGAccord)
Quaife = lifetime warranty
Old Jan 15, 2003 | 12:13 PM
Default Re: h22 question (Nick M)
This a daily driver and not a strip car, so is the quaife really neccessary? I mean will I break the jdm lsd daily driving and such?
[Modified by johnsaccord, 4:13 PM 1/15/2003]
Old Jan 16, 2003 | 09:10 AM
KGAccord's Avatar
lsd is not really that necessary if your just going to daily drive anyway. it helps you corner too along with giving you 2 burnout marks.
Old Jan 16, 2003 | 09:37 AM
So, you wouldn't suggest lsd for a daily driver (only car)??? Everyone I talked to said go with lsd, just in this case I am debating if the newer non-lsd tranny will be better.
Old Jan 16, 2003 | 10:55 AM
KGAccord's Avatar
it's nice, but if you don't plan on racing it or really pushing hard then it's kind of a waste of money. I would like one if a could have afforded one when i did my swap.
Old Jan 16, 2003 | 04:26 PM
m0t0rhead's Avatar
if you want to race.. it will lower your E.T. and give you more power to the ground in turns.
Old Jan 16, 2003 | 04:29 PM
BigChris's Avatar
get the LSD. I hate the freaking torque steer in my car when i push it. For normal driving its ok but when you give it some gas you will want the LSD. Definitely get the Quaife LSD!
Old Jan 16, 2003 | 04:42 PM
SearchBeforeUPost!'s Avatar
Default Re: h22 question (BigChris)
go with the newer motor without lsd. the obd2-->obd1 conversion will be more of a headache than upgrading to an quafe lsd. who knows, you might not even look into getting one. i don't have one, and i don't really have an overwhelming desire to get one anytime soon.
Old Jan 16, 2003 | 04:44 PM
m0t0rhead's Avatar
Default Re: h22 question (Bda91acc)
I would also go with the newer motor. Although the shape of JDM motors is sometimes iffy.. plus they are from right hand drive cars.. so wiring them up is a bitch. I would recommend doing the OBD2 to OBD1 conversion as OBD2 will seriously limit your potential and gains.
Old Jan 16, 2003 | 04:48 PM
Default Re: h22 question (Escobar)
wiring them is no different then wiring a usdm motor. you don't use the harness that comes with the engine, you use the accord harness.
Old Jan 16, 2003 | 05:20 PM
m0t0rhead's Avatar
you have to extend the wires and solder 2x instead of once per wire.
Old Jan 17, 2003 | 05:22 AM
Let me say it again, I AM buying an obdII jdm h22 that has a non-lsd tranny. My only question was should I keep that tranny or get the lsd tranny (which will probably be older) and put it on the SAME jdm obdII h22. I do not have to deal with converisons as the motor is obdII and my car is obdII, the tranny doesn't make a difference, nor does the wiring.
LSD or NO LSD, that is the question...
Old Jan 17, 2003 | 05:29 AM
BigChris's Avatar
Once again, get the LSD
tofast4uh22
Mar 14, 2009 10:08 PM
Broken Devil
Jul 1, 2005 06:33 PM
-Bionic-
Aug 7, 2003 06:39 AM
4thgenturboSi
Apr 24, 2003 11:43 AM
Propulsion
Jun 5, 2002 05:04 PM
