Gear Ratio considerations
I'm considering changing my Prelude H22a tranny to an Accord Type-R H22a tranny here's the comparison:
Well here is my direct comparison of the type-r to what I have now:
Prelude - ATR
3.307 - 3.285
1.950 - 2.090
1.360 - 1.481
1.071 - 1.071
0.870 - 0.870
Final 4.266 - 4.266
So first is very similar, but it's 2nd and 3rd where you see the big jump! Is this a no brainer? This is simply a better tranny no? I am moving my powerband up a little higher, and I was thinking the shorter 2nd and 3rd would be better to get me into the high revs faster....
Any thoughts? Anyone have any links to some rpm and speed calculators for ratios?
Prelude - ATR
3.307 - 3.285
1.950 - 2.090
1.360 - 1.481
1.071 - 1.071
0.870 - 0.870
Final 4.266 - 4.266
Hybrid the sucker.
Keep the prelude 1st and get the accord 2nd and 3rd.
but I take it you like the 2-3?
What is your powerband going to look like and what will this motor's redline be? I.e., are you looking to stay between say 6000-8000 RPM during shifts or what?
Regular H22a crank will make peak torque at 5500 and peak hp at 6800
My F20B crank will 'probably' make peak torque at 6500 and peak hp at 7500-8000 redline will be 8500
[Modified by satan_srv, 4:38 PM 1/15/2003]
Damnit, I just noticed you are wanting an 8500 RPM redline. I'll correct that last post as soon as can crunch the numbers.
calculations for the Prelude tranny w/ a 23.5" tire -
1st (3.307): 42 mph @ 8500 RPM
2nd (1.95): 42-71 mph ... 5000-8500 RRM
3rd (1.36): 71-102 mph ... 5900-8500 RPM
4th (1.071): 102-130 mph ... 6700-8500 RPM
5th (0.87): 130-160 mph ... 6900-8500 RPM
cruise @ 65 mph in 5th: 3450 RPM
calculations for the ATR tranny w/ a 23.5" tire -
1st (3.285): 42 mph @ 8500 RPM
2nd (2.09): 42-67 mph ... 5350-8500 RRM
3rd (1.481): 67-94 mph ... 6050-8500 RPM
4th (1.071): 94-130 mph ... 6150-8500 RPM
Now that your RPM limit is so much higher, you would see some good benefit from moving to a numerically higher final drive. For example, using a 4.785 final w/ the ATR tranny (definitely the better of the two, though not optimal):
4.785 final
1st (3.285): 38 mph @ 8500 RPM
2nd (2.09): 38-59 mph ... 5450-8500 RRM
3rd (1.481): 59-84 mph ... 6000-8500 RPM
4th (1.071): 84-116 mph ... 6150-8500 RPM
5th (0.87): 116-143 mph ... 6900-8500 RPM
cruise @ 65 mph in 5th: 3850 RPM
4.785 final
4.785 final
4.785 final
FD-P47 Ring/Pinion Set, Prelude (4.7143 ratio) $1250.00
Prodrive I think is one of the only companies that makes a FD for the prelude...damn that's some expensive ****!
if you got the money for the tranny, I think that its a no brainer, as for the final drive, it will help a little bit, but not near worth the price.
the tranny would probably cost more than that, considering it's exclusivity. And at any rate, a 10% shorter final drive will make a bigger impact on overall performance than the slightly better spaced 1-3 of the ATR tranny. I'd opt for the new final gears if the prices are about the same.
n'vamind...just read the entire post
[Modified by dsludefosho, 11:26 AM 1/28/2003]
Hybrid the sucker.
satan_srv
Jan 15, 2003 12:44 PM
