Intake manifold sensors/connectors.
Old Jan 15, 2003 | 09:24 AM
TurboEF9's Avatar
Default Intake manifold sensors/connectors.
I'm doing my MPFI swap, messed something up and it's not working. Kind of chugging and doesn't want to stay running.
All wiring quadruple checked. Everything.. except the connectors. Seems I'm missing one and need to figure out where things go on my intake manifold.
Here's a pic.. what are 1 two and three, and if someone happends to know the color of the wires that the connectors go to, or if I even need all of them, that would be great help, thanks everyone!
Old Jan 15, 2003 | 09:31 AM
SEA Hag's Avatar
Default Re: Intake manifold sensors/connectors. (TurboEF9)
Is that from a 3rd gen civic?
Old Jan 15, 2003 | 09:32 AM
Doctor CorteZ's Avatar
1 - EVAP purge solenoid
2 - IAT sensor
3 - MAP sensor
is that a D16Z6 mani ?
and your car is a 4th gen ?
[Modified by Doctor CorteZ, 10:34 AM 1/15/2003]
Old Jan 15, 2003 | 09:41 AM
TurboEF9's Avatar
Default Re: Intake manifold sensors/connectors. (Doctor CorteZ)
Ya.. My car is a 4th gen hatchie, and that manifold is from a 5th gen.
I think this is where my problem is coming from.
It seems I only have three connectors from my DX hatchie. The EVAC, the TPS, and "another one" that is white and I don't know exactly what it is. :-/ Maybe IAT?
This manifold *WAS* running on the same setup in a different car, but I can't seem to figureout what the problem is.
I know it was running without the map sensor on top of the throttle body. But, I don't know if it was using all of those connectors from the DX harness.
Old Jan 15, 2003 | 09:45 AM
not running properly , unless you're using the MAP on the firewall from your old setup.
Old Jan 15, 2003 | 09:46 AM
TurboEF9's Avatar
Ya.. the MAP sensor on my firewall is what is being used now.. I just need to hook up vacuum lines to the intake manifold to make the MAP work from that one right?
Old Jan 15, 2003 | 10:37 AM
the MAP sensor on top of your TB is what needs to be used.
extend the wires and use that one , ditch the one on the firewall.
Old Jan 15, 2003 | 10:39 AM
serious's Avatar
i believe so, but the better thing to do is extend the wires from the firewall mounted one and use the new map sensor on the manifold.
also, number 1 should the evap purge, which should currently be on your firewall. it'll work fine as long as you run the vacuum lines correctly.
Old Jan 15, 2003 | 10:52 AM
TurboEF9's Avatar
Default Re: Intake manifold sensors/connectors. (serious)
OK, minor update. I checked the voltage of the EACV, and it doesn't seem to have voltage!
My Haynes (worthless book) said to check for an open circut between the positive wire of my EACV and the PGM-FI main relay..
Uhm, how the heck do I do that?
Old Jan 15, 2003 | 11:23 AM
read the book , the PGM-FI relay is above the left kick panel by the hood release.
Old Jan 15, 2003 | 04:24 PM
89dxhunchback's Avatar
its not throwing any codes ?
ShinobiLude
Dec 29, 2005 12:55 PM
Charri
Sep 13, 2005 12:09 AM
honDA16
Nov 4, 2004 01:25 PM
