Flashing battery light on odometer
Old Jan 15, 2003 | 08:21 AM
bjaeyang's Avatar
Default Flashing battery light on gauge cluster
Is this a sign of a bad alternator? It's only sometimes that the battery light goes on or is this some kind of electrical problem? It's not the battery because i switched batteries. Your help is appreciated.
by the way i have a 90 accord lx autotragic.
[Modified by bjaeyang, 5:22 PM 1/15/2003]
Old Jan 15, 2003 | 08:22 AM
paulzy's Avatar
Default Re: Flashing battery light on gauge cluster (bjaeyang)
is it dying yet? that's one sign of a ad alternator...either that or you have a short in your harness somewhere
Old Jan 15, 2003 | 08:25 AM
Charlie Moua's Avatar
Default Re: Flashing battery light on gauge cluster (1320development)
try adjusting the belt to spec
Old Jan 15, 2003 | 08:36 AM
bjaeyang's Avatar
Default Re: Flashing battery light on gauge cluster (Charlie Moua)
you say adjust the belt to specs? Shiet i never knew that i just adjust it til it's tight and not squeak. And sometimes the car wont start up on its first try.
Old Jan 15, 2003 | 08:47 AM
Stew Pidasso's Avatar
Same thing happened to me until my alternator finally gave up. Your alternator is dying. Have it checked at a local auto parts store. Check the plug first to make sure it is making a good connection.
Old Jan 15, 2003 | 08:56 AM
YeuEmMaiMai's Avatar
Default Re: Flashing battery light on gauge cluster (Stew Pidasso)
and I would definately replace that thing yourself if you can as they are NOT cheap
Old Jan 15, 2003 | 09:57 AM
bjaeyang's Avatar
Default Re: Flashing battery light on gauge cluster (YeuEmMaiMai)
alternator is diy for me. pretty simple. Takes me about 1 1-2 to 2 hrs. So it sounds like the alternator is go bad? Its not cheap but i think i still got warranty under autozone on it. If not i gotta accord im parting. Alternator is brand new if i rememer.
Old Jan 15, 2003 | 10:06 AM
user86's Avatar
First of all, (if the battery you replaced it with, isn't new then I would test the water. And second of all you need to be in a shop to test your alternator. You need shop testing equipment to determine the problem.
Old Jan 15, 2003 | 05:26 PM
Bantam's Avatar
2nd Coolest Person in DFW
My battery light came on once too. That was when I had it to the floor at about 5,000rpm. I felt a sudden kick of acceleration hit and so, my alternator belt had disentegrated. I replaced It, but I am a dumbass and just can't seem to make that thing stop sqealing when it starts, I guess Ill have to adjust it for the third time this weekend if it isnt too cold<--Texas weather is irradic.
Old Jan 15, 2003 | 05:55 PM
jingjing's Avatar
really? it only took me about 20 mins to take mine out when i switched my pullies.
Old Jan 16, 2003 | 08:46 AM
bjaeyang's Avatar
Default Re: Flashing battery light on gauge cluster (jingjing)
20 mins.?? woow! 1 1/2-2 because its cold *** hell outside and gotta run to the parts store to grab the new alternator and return core. And plus this is your a 4th gen. Gotta take the power steering pump out to make it much much easier.
Old Jan 16, 2003 | 09:19 AM
carolinaACCORD's Avatar
i replaced mine in about 30 min., had the new one delivered while i took off the old one. very easy job.
Dafredsta05
Aug 31, 2016 09:53 AM
mayfly
Jun 28, 2009 04:34 PM
Tim 95 M3
Mar 12, 2009 02:17 PM
da9pwnsu
Jan 19, 2007 12:12 PM
fe519
Sep 23, 2003 03:25 AM
