94 civic ..will itr master cylinder work with gsr discs
i just bought a 94 civic coupe dx and it has no motor .... a itr master cylinder and gsr brake converion to the front and back... will this be ok.. will it run fine, and will brakes actually feel stronger??
also im going with the type r motor, what rad. in the civic should i use? will i have to change it in any way.. thanks,Randy
It will work just fine but you will need the GSR proportioning valve and i'm pretty sure you will need to swap out the booster as well. You will also need to bend and re-flare the brake lines at the MC. Its not too hard to do but get a flaring kit from any hardware store and practice on some spare lines to get the hang of it before you get too into it.
Mike
Mike
sidewayz2013
May 7, 2015 06:02 PM
killacam20
Aug 13, 2007 02:38 PM
jr_istheman
Jun 24, 2003 11:05 AM
jr_istheman
Jun 23, 2003 05:17 AM
