Jun Cams VS Skunk2 Cams
Old Jan 14, 2003 | 09:28 PM
JDMSI's Avatar
Default Jun Cams VS Skunk2 Cams
What do you guys thing is better skunk2 stage1 cams or the Jun3 cams?
Old Jan 14, 2003 | 10:33 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Jun Cams VS Skunk2 Cams (JDMSI)
your kidding, right?..IMO skunk cams suck, Jun 3's are better, but then again IMO Toda is better then Jun, so its a endless cycle
Old Jan 15, 2003 | 04:02 AM
rolow's Avatar
Default Re: Jun Cams VS Skunk2 Cams (SIXTYdashONE)
Its an unfair comparison!
Skunk2 stage 2 VS. Jun stage 3's are close in specs.
I have a set of skunk2 stage 1's and 3's but would get the Jun's if the money was right.
Old Jan 15, 2003 | 08:43 AM
1bad-eg's Avatar
It all depends on the setup you run or are going to run, and if you want the powerband high or low in the rpm range.
Old Jan 15, 2003 | 08:51 AM
au-gsr's Avatar
Default Re: Jun Cams VS Skunk2 Cams (1bad-eg)
well the only midrange cams i know of are the ctr and ITR. skunk2 stage 1-3 are high rpm performance cams, same with jsut aout any other manufacturer out there unless their specs are very close to the 2001 itr/ctr cams. you need to go to Team-Integra.net sign up and read the countless articles they have saved on cams and compression and setup for the engines and . . . cams are a lil more diffcult to work with than most people realize. its not a staright bolt in and away ya go. you need teh proer compression then you need the right timing and the proper fuel/air ratio then you need. . . well you get the idea.
Old Jan 15, 2003 | 09:01 AM
straightline's Avatar
First off skunk cams do not suck, when you say one manufacturer is better than another just by name that isn't very smart. The cam that is the best is what works for your set up, skunk makes cams for a fraction of the price of toda and make a couple diffrent profiles that work well with certain set up. I know alot of people running skunks,toda, and jun (I had jun 3 now I run skunk 3). From numbers I've personally seen on the dyno Toda (B&C) where both below JUN 3, haven't dynoed skunk stage 2's but my skunk 3's are in my car cause for my set up I made the most power with them(over JUN). Toda D's look good but have never even seen them in action. It's all about set up and money, Toda $900&up, Jun 900, got my skunks for 600.
Old Jan 15, 2003 | 09:24 AM
GreenR's Avatar
Skunk cams suck based on what. There are H-T members making 200whp with Skunk stage 1's and stock compression in a B18C5. How much power/$ spent have you made?
I think that JUN 3's are not comparible to the Skunk stage 1's because they were made for different purposes (i.e., Skunk stage 1 are C.A.R.B. legal and very close to stock ITR cam profile and JUN 3's require higher compression to maximize potential and are not C.A.R.B. legal designed for more track and less street)
Old Jan 16, 2003 | 04:33 PM
advanracing62's Avatar
Default Re: Jun Cams VS Skunk2 Cams (straightline)
I'm still a JUN fan though..
Old Jan 16, 2003 | 05:32 PM
Default Re: Jun Cams VS Skunk2 Cams (advanracing62)
Don't get me wrong JUN cams are great, just that I hate when people say stuff about a product they don't know about in a negative way. JUN Skunk
Old Jan 17, 2003 | 03:55 AM
TimoneX's Avatar
New User
Jun is perceived as being better automatically simply because the price is higher.
Old Jan 17, 2003 | 07:56 AM
EleanoR's Avatar
Default Re: Jun Cams VS Skunk2 Cams (TimoneX)
well said
Old Jan 19, 2003 | 07:13 PM
HT's Biggest Loser
Default Re: Jun Cams VS Skunk2 Cams (EleanoR)
I am going by experience, its not liek im favoring JUN because of the name, so i dunno where u get that idea from, i still do not liek skunk cams
Old Jan 19, 2003 | 08:04 PM
icelarry27's Avatar
So true. Not all the time does a higher price mean better....but sometimes...
Old Jan 20, 2003 | 12:38 AM
If You Slip You Die's Avatar
Default Re: Jun Cams VS Skunk2 Cams (GRCuadros)
I rather have JUN cams over Shunk cams
Old Jan 20, 2003 | 12:40 AM
Al Bundy's Avatar
Default Re: Jun Cams VS Skunk2 Cams (lilxjoker)
JUN
Old Jan 20, 2003 | 05:41 AM
TimoneX's Avatar
New User
I would too if price were no object, but for what Jun gets, If I were given Jun3s, I just may sell them, buy something else, and pocket the difference. I doubt it'd be skunk stg1s however as the original comparison suggested.
Old Jan 21, 2003 | 07:57 AM
andrewasf77's Avatar
Default Re: Jun Cams VS Skunk2 Cams (GreenR)
do you remember who it was that was making that power?
Old Jan 21, 2003 | 08:43 AM
all motor b20b's Avatar
I thought skunk2 were better then I tried jun and I'll never go back. Thats just my opinion though.
Old Jan 21, 2003 | 10:45 AM
Si's Avatar
Si
Would the brand really matter? I mean you gotta go with what's higher quality, but aren't the specs of the cams what's really important? I would go for the cams that would give more power have better durability, not because of the brand.
Old Jan 21, 2003 | 11:34 AM
TimoneX's Avatar
New User
Default Re: Jun Cams VS Skunk2 Cams (RedSi99)
Here's where the problem lies. Some of the important specs are not listed, ramp rates for instance. I have yet to ever see this quantified for any of the top performing cams. As far as durability goes, it's always hard to say. For instance when I hear about xyz cam breaking the first question has to be who installed it? Did they do it right? Would they admit it if they made a careless error? I like cams made by Jun, Toda, Skunk2, and Crower, I think they all make great cams. Two of those companies price gouge IMO however. Too many people don't do all the research required for high lift long duration cams and end up being disapointed.
Old Jan 21, 2003 | 12:03 PM
Si's Avatar
Si
They also end up trashing their engine, ex. having the piston slam into the valves.
Old Jan 21, 2003 | 12:11 PM
TimoneX's Avatar
New User
True but if they spent all that time & money and couldn't even be bothered to check for clearance before starting the motor then...well I wouldn't say they deserve it exactly, but they really have noone to blame but themselves.
Old Jan 21, 2003 | 01:48 PM
Halo's Avatar
These vague one liner responses always puzzle me...WHY would you rather have JUN cams over Skunk?? What is your logic for saying this?
Old Jan 21, 2003 | 02:26 PM
TimoneX's Avatar
New User
Default Re: Jun Cams VS Skunk2 Cams (Halo)
Well aside from the perception that Jun is better simply because they cost more than skunk2, I've seen some really impressive charts with Jun3 cams. Admittedly my experience with Skunk2 cams is limited, but I was set to go with them b4 I got a really great deal on my Crowers. Skunk2 is in my book, just for keeping the cost reasonable.
pu5sipoppr
Nov 9, 2004 08:03 PM
SnkyPY
Feb 25, 2004 01:28 PM
Convoy
Sep 29, 2003 06:48 AM
(__________)
Sep 10, 2002 11:01 AM
.Ryan
May 11, 2002 09:27 AM
