Rear washer trick don't work.
Old Jan 14, 2003 | 08:33 PM
State_of_mind's Avatar
Default Rear washer trick don't work.
well, i bought 4 bolts and washer from orchard.......7 bucks total......
i add alot of washer to the orginal arm......until the arm joint almost touch the frame.......my negative camber still alot......how can you fix it?
will skinnny tire (width) make the car bend more? thats why i have more negative camber....
Old Jan 14, 2003 | 08:37 PM
ArchAngel Sabastian's Avatar
New User
Default Re: Rear washer trick don't work. (State_of_mind)
it does work.
what size rim/tire are you using. how low are you.
ive done the trick on several accord with a 1.5inch - 2.25inch drops.
Old Jan 14, 2003 | 08:43 PM
ratherbewalking's Avatar
Default Re: Rear washer trick don't work. (ArchAngel Sabastian)
you have to put the washers under your wheels.
Old Jan 14, 2003 | 08:45 PM
New User
Default Re: Rear washer trick don't work. (ratherbewalking)
wha?
Old Jan 14, 2003 | 09:43 PM
sorry , wat i mean was; the trick doesn't fix the negative camber to stock......still have negative camber......i guess i lowered too low.......3.5inches.
Old Jan 14, 2003 | 10:19 PM
iam7head's Avatar
Yes you got your answer right there..
Old Jan 15, 2003 | 12:35 AM
TypeSH's Avatar
Default Re: Rear washer trick don't work. (iam7head)
can you do me a favor and measure the length of the stock bolt? and if possible post a picture of it? I need to be certain stock 45mm long, and that the flange bolts i bought from Orchard (10.9 metric grade bolts there )have enough thread on the end (part threaded, part smooth bolt) on it before I try to put them on.
AzntaggeR
Jul 14, 2003 11:26 AM
lil k
May 19, 2003 12:22 AM
dellman177
Oct 3, 2002 06:59 PM
p0pe
May 22, 2002 06:30 AM
fcuked
10
May 8, 2002 09:18 PM
