What does this bulb do??
Old Jan 14, 2003 | 06:24 PM
Adampops's Avatar
Default What does this bulb do??
part number 19, that bulb, what is its function. Part number 18 is the blinker and parking lights, and ive tried my hazards and everything and bulb number 19 never lights?
Old Jan 14, 2003 | 06:29 PM
Chiovnidca's Avatar
Default Re: What does this bulb do?? (Adampops)
It's a parking light. It should be on with the headlight switch in the 1st or 2nd position.
Old Jan 14, 2003 | 06:51 PM
Adampops's Avatar
Default Re: What does this bulb do?? (Chiovnidca)
when my lights are in the first or second position that is when bulb 18 is on. Everyhing is bulb 18. Is there something wrong w/ my car, or the way it was wired??
Old Jan 14, 2003 | 06:59 PM
b19coupe's Avatar
Could be a bad bulb. Or a wiring problem. Or a problem with the integrated control unit. I was just working on a 95 Integra that had the same problem. Bulb was good, headlight switch and wiring between headlight switch and bulb was o.k. Found a bad integrated control unit-power goes from the switch through the integrated control unit to the bulb. Power going in, but none coming out. Check the bulb first.
tei344
Mar 7, 2008 05:36 PM
ogawa_jiei
Sep 23, 2006 06:10 PM
eg8000rpm
Apr 27, 2005 12:37 PM
