If You Only One Piston Working Right...
Old Jan 14, 2003 | 03:47 PM
Fatty_1775's Avatar
Default If You Only One Piston Working Right...
If you had one piston working on a B16 or B18 or any engine is it still drivable? Or can you get around with only one cylinder?
Old Jan 14, 2003 | 03:54 PM
tominos's Avatar
Default Re: If You Only One Piston Working Right... (import_racer)
my d16 ran on only 2 pistons once. ran pretty rough.
Old Jan 14, 2003 | 05:35 PM
Fatty_1775's Avatar
Default Re: If You Only One Piston Working Right... (tominos)
Anyone else have any thoughts on this matter?
Old Jan 14, 2003 | 07:39 PM
b19coupe's Avatar
Don't think you would be able to drive with just one cylinder firing.
Old Jan 14, 2003 | 07:43 PM
Desslok's Avatar
Default Re: If You Only One Piston Working Right... (b19coupe)
Unplug 3 of your spark plug wires and let us know>
Old Jan 14, 2003 | 08:38 PM
EpDarks's Avatar
Default Re: If You Only One Piston Working Right... (sp)
There's no way 1 B16 piston could rotate the entire assembly.
2 is do-able, but 1 is not likely at all.
Old Jan 14, 2003 | 08:51 PM
Nameless RB26's Avatar
Default Re: If You Only One Piston Working Right... (EpDarks)
And pumping gasoline into the other cylinders that are not working will cause wear. The gasoline will disolve the oil on the cylinder walls... not good.
downeyballz
Jul 6, 2008 01:21 PM
qazaq
Jul 14, 2007 04:20 PM
jennsGSR
Aug 17, 2006 06:12 PM
seako_916
May 19, 2004 09:28 PM
seako_916
May 19, 2004 08:52 PM
