adjusting clutch pedal...
Old Jan 14, 2003 | 03:02 PM
servion's Avatar
Default adjusting clutch pedal...
I did a search and found how to adjust a clutch pedal on a hydroaulic setup... but what would cause you to need to do this?
I just put in a new clutch in my '93 si with a b18c... went from stock pressure plate to an act xtreme. Now, the first 1/4 of pedal movement is all play. Should I try to adjust it out, or is this a symptom of another problem?
Old Jan 14, 2003 | 06:11 PM
servion's Avatar
Default Re: adjusting clutch pedal... (servion)
Old Jan 14, 2003 | 06:53 PM
Colton Grundy's Avatar
i want too know too
Old Jan 15, 2003 | 07:05 AM
servion's Avatar
anyone?
Old Jan 15, 2003 | 07:11 AM
misledyouth's Avatar
New User
it might just be flex in the rubber line. but i would blead it again then try to adjust out some of the slack. You do the adjusting to get the looseness out of the pedal.
jesse
Old Jan 15, 2003 | 02:39 PM
servion's Avatar
Default Re: adjusting clutch pedal... (misledyouth)
I've bled it 2 times... I'm thinking its something to do with the new pressure plate.... does anyone know?
Old Jan 15, 2003 | 03:45 PM
tominos's Avatar
if it still shifts into gear, with no problems i wouldn't worry about it. mine has a little play too.
Vinde
Transmission & Drivetrain
Oct 30, 2014 08:14 AM
redline7
Feb 23, 2008 08:53 PM
RTW DC2R
Jun 23, 2006 07:42 AM
TrojanMan01
Sep 21, 2005 10:07 AM
GSR-T-
Nov 20, 2003 10:12 AM
