custom exhaust= leaner???
Old Jan 14, 2003 | 01:08 PM
Mires's Avatar
Default custom exhaust= leaner???
I am having a problem with black smoke cause i am running too rich. If i put a custom exhaust on then will it reduce the black smoke??
Old Jan 14, 2003 | 01:10 PM
Chris N's Avatar
Default Re: custom exhaust= leaner??? (ITR-862)
No.
You have to alter your air/fuel ratio to be less rich.
Old Jan 14, 2003 | 01:11 PM
azn98R's Avatar
nothing to do with your exhaust
Old Jan 14, 2003 | 01:39 PM
ITR184's Avatar
How bad is it smoking?
Old Jan 14, 2003 | 01:44 PM
Big Phat R's Avatar
Reduce fuel pressure and/or check your ignition system.
Old Jan 14, 2003 | 02:12 PM
Mires's Avatar
Default Re: custom exhaust= leaner??? (Freekzilla)
Its smoking pretty bad. After a few days there will be black specs all over my bumper. Its starting to **** me off. Thanx for the info guys.
Old Jan 14, 2003 | 03:22 PM
00MRSi's Avatar
What are your mods? Have you altered your air/fuel ratio, fbr used, etc? Remember Hondas run rich from the factory. I don't have an R, but on my 00 SI I have only AEM CAI and APEXi N1 catback and I start to get some black soot near the muffler and on the rear bumper. It's not a considerable amount, but over time, especially using VTEC your gonna get some exhaust residue.
Old Jan 14, 2003 | 03:35 PM
disordeR's Avatar
Default Re: custom exhaust= leaner??? (00MRSi)
Try resetting your ECU and letting your car idle for a little bit...?
[Modified by disordeR, 4:35 PM 1/14/2003]
Old Jan 14, 2003 | 03:39 PM
B_CRUZ!'s Avatar
ummm do you still have a cat?
Old Jan 15, 2003 | 06:40 AM
Mires's Avatar
Default Re: custom exhaust= leaner??? (B_Cruz)
all i have is CAI
Old Jan 15, 2003 | 06:41 AM
Chris N's Avatar
It's from running rich!! Go tune your a/f already.
Old Jan 15, 2003 | 08:58 AM
vtec.dc2's Avatar
check your air filter.. are you running a cat?
Old Jan 15, 2003 | 10:15 AM
Chris N's Avatar
Default Re: custom exhaust= leaner??? (vtec.dc2)
What's with everyone? He said 'all I have is a CAI'.
Black on the bumper is from running rich. Where's the confusion?
If you are really worried about it, maybe the rings are going. You could check that out. Personally, I'd say it's just from running rich. How are you driving? After one track day (starting with a clean car), I had black all over my bumper and inside of my wing. Why? Running rich!! The only way to stop it is to tune, lean out the fuel a bit... or stop driving so hard.
[Modified by Chris N, 1:16 PM 1/15/2003]
Old Jan 15, 2003 | 10:34 AM
Willard's Avatar
Default Re: custom exhaust= leaner??? (Chris N)
Check out Kevin's (krbobcat) stock dyno plot...
Looks a little rich on the top end..
Old Jan 15, 2003 | 10:35 AM
Chris N's Avatar
Default Re: custom exhaust= leaner??? (Willard)
Looks familiar, like all stock itr a/f ratios: a 'little' rich on top.
rice h8r
Jun 27, 2010 10:51 AM
skata89
Nov 6, 2006 06:36 AM
b00sted_GS-R
Aug 14, 2004 01:16 PM
pRosmAt3c
Sep 7, 2003 01:27 AM
InfamousRS
May 23, 2002 01:17 PM
