Wiring/making a start panel
Old Jan 14, 2003 | 12:50 PM
Want2race's Avatar
Default Wiring/making a start panel
I assume no liability for anything going wrong!
OK this is for the long acre switch.
I know millions of people have been emailing me about it.
the large white wire that goes to the back of the switch. I cut that and connect it to the brown wire on the longacre switch ( thats the power source wire)
The blk/white wire is your ignition system. On the longacre switch this goes the yellow wire.
The blk/yellow wire is your started solinoid. It goes to the green wire.
As for the wiring on the back of the switch I cannot say how that goes.
I would imagine that it goes like this:
Power wire(white) goes to 1 side of a spst switch. then a short wire goes from that same terminal to a momentary heavy duty switch. The other side of the SPST switch will connect to the ignition wire ( blk/white). And finally the other side of the momentay switch will recieve the starter solinoid wire ( blk/ yellow)
goodluck!
this is for a 88-91 CRX honda
RiipTiide67
Jan 3, 2012 01:37 AM
sloem2
Honda Civic (2001 - 2005)
May 14, 2007 08:25 PM
hybridreams
Aug 10, 2003 06:22 PM
JDubya
Audio / Security / Video
Jun 18, 2003 06:10 AM
Want2race
Jan 14, 2003 12:51 PM
