clutch cable position
well i did a search and read a bunch of post and nothign rally helped me out. I have a question about the routing of the clutch cable.
the cable has a metal ring crimped around it (about the middle of the valve cover, where a raket to help hold it is.) do i need to place the ring on the left or right side of the bracket (as i face the engine) or does it matter? I was lookign for a pic of it to help explain, but couldnt find one quickly of the cable. (a basic close up of a valve cover shoudl show it)
#2 what is the correct procedure for adjusting the clutch. (going form hydraulic to cable is throwign some wreches in the process.
here is a pic to help reference the adjusting.
i already haev everythign in place but teh lever would have to be pulled way up to get the metal ring onthe left side of the bracekt.
thanks guys
thanks guys
From: the asshole of america..., upstate new york, USA
doesn't matter on the whole thingy holding up your clutch cable...keep a 1/4 to 1/2 inch clearance from the throwout bearing to the pressure plate, otherwise you'll end up replacing both of them
i know this is a b18 but image an A6 instead i have pointed out where the crimp is (apx.) and even drawn it in. any help would be great.
