TDC pointer?
Old Jan 14, 2003 | 06:37 AM
Soled Out's Avatar
Default TDC pointer?
IM doing a timing belt job on my JDM B16A II ...and it doesnt have the normal triangle/line pointer above the crank pulley like the SOHC motor had, so where am i suppose to line the dot up to set it at TDC? On the left side of the timing belt cover there is a slanted line about 2'' long, is that what i use? Or is there some other mark that im failing to see?
Old Jan 14, 2003 | 10:09 AM
Soled Out's Avatar
Default Re: TDC pointer? (Gray EG on Jack Stands)
Nvm i figured it out
another eg
Sep 9, 2015 02:04 PM
DavidCRV
Aug 26, 2013 03:12 PM
shark13
19
Sep 23, 2012 11:21 AM
ScottEK
13
Sep 25, 2002 08:23 PM
Carp
Oct 15, 2001 11:05 AM
