camber kits for an ef
Old Jan 13, 2003 | 05:35 PM
crx91-sir1's Avatar
Default camber kits for an ef
I have a 91 crx and i lowered it. I wanted to know what camber kit to get. Everyone i have talked to says skunk2, but i can't find one that fits on my car.
Does skunk2 make one for my car and if not , what companys make good ones.
Old Jan 13, 2003 | 05:40 PM
FourthGenHatch's Avatar
Default Re: camber kits for an ef (crx91-sir1)
I think Ingalls is better. It replaces the anchor bolts and allows the UCA to slide in and out, then you lock it down with a big nut and it won't budge. Was like $112 for all the kits for the front.
Old Jan 13, 2003 | 05:43 PM
neutron91's Avatar
Default Re: camber kits for an ef (FourthGenHatch)
ingalls
bryant's Avatar
Default Re: camber kits for an ef (neutron89)
skunk2 doesnt make them for ED's
Old Jan 13, 2003 | 05:44 PM
USDM 4G VTEC's Avatar
i am very interested on this also....
i will like to know all the options available for the EF chassis.. i dont care for the rear since it can be fixed with washers....
but i was wondering if anybody here has even used the adj ball joints and if they are reliable... i am getting a camber kit for sho with my tax money and need to know wich one will be good...
Old Jan 13, 2003 | 05:51 PM
crx91-sir1's Avatar
where can i buy ingalls and what do i have to do to put them on.
thanks
Old Jan 13, 2003 | 05:55 PM
Groupbuycenter.com had them a while ago. To put them on your just unbolt the anchor bolts from the chassis then from the UCA. It's easy.
Old Jan 13, 2003 | 05:57 PM
neutron91's Avatar
http://www.iapdirect.com ... $130 shipped
Old Jan 13, 2003 | 06:42 PM
drjondurst's Avatar
whats the diff between the "Ingalls Extreme Front Adjustable Camber Anchor Bolts" and the "Ingalls Front Adjustable Camber Anchor Bolts"? Is it only the amount of degrees that the kits will correct? My crx is lowered about 2.5 inches, which kits do you think I should get?
Old Jan 13, 2003 | 06:54 PM
NCchris's Avatar
Default Re: camber kits for an ef (JDM EF9)
Specialty Products adjustable ball joints
http://www.spcperformance.com/PerfPa...ages/67320.jpg
HTH
chris
Default Re: camber kits for an ef (drjondurst)
the regular fixes up to 1.0 deg and the extreme fixes 1.25-3.0 deg
Old Jan 13, 2003 | 06:55 PM
i will also will like to know wich one to order... they dont specify what kind of lowering, but they say how much they correct... how do we know how much camber we have to correct so we know wich one to order!!
Old Jan 13, 2003 | 11:06 PM
90Hatch's Avatar
Ingalls - Groupbuys.com = $110
Old Jan 13, 2003 | 11:08 PM
90Hatch's Avatar
Default Re: camber kits for an ef (90Hatch)
Groupbuyscenter.com......oops, but ya theyz good
Old Jan 14, 2003 | 06:27 AM
REDBARON's Avatar
Hey JDM EF9, go to http://www.Ingallseng.com
They have some good info that will help you determine which camber kit to buy.
Old Jan 14, 2003 | 08:17 AM
jc836's Avatar
You need to do an alignment before you go buy any parts. Both Ingalls and Specialty have adjustable anchor bolt kits fit the 89-91 CRX. I have to use the Specialty "eccentric" ones for Improved Touring-but you can use either brand for daily and autocross.
Keep something in mind-the amount you drop the car helps determine how much correction is needed and which kits are best for you. My Civic has the adjustable upper control arms and they work very well. If you are over 2" of drop this is another solution. Both Ingalls and Specialty have Tech support for free (800#). Where to buy your parts-I get ALL of mine from Ultra Performance in Tucson-terrific pricing and service.
Old Jan 14, 2003 | 08:29 AM
SiR Kid's Avatar
New User
Default Re: camber kits for an ef (jc836)
I'd go with the adjsutable ball joint from SPecialty before buying the offset control arm mount style.
Just personal preference, but I saw this setup at the SEMA booth Specialty had up, and they were NICE. Plus I need new ball joints anyway
JWhonda_ride
Apr 26, 2011 08:57 PM
Charlie Moua
Oct 5, 2010 07:17 PM
misha
Suspension & Brakes
Jul 11, 2009 04:07 PM
jdmhondacrx
Suspension & Brakes
Mar 6, 2008 11:06 PM
Mac
Jul 26, 2006 04:08 PM
