B16A in 1st Gen CRX, Which Header Will Fit?
I'd like to get a 4-1 in there, but I don't know if its possible. I read in another post that someone had the Toda header in thiers, but had to cut the center radiator bracket or something. For the people out there with a setup like in the title, what kind of header are you using, and did you have to make any modifications to anything to make the header fit? Thanks
small mods as in what? are we talking bashing some things and cutting some brackets, or a smaller radiator?
This should probably go into tech right about now, but whats the best bang for the buck 4-1 header for the B16? Somewhere around 400 or less?
I have a 4 2 1 dc sports header on mine. Not as much cuting into the cross member is needed when using a 4 2 1. they are better for low end power too
well its in a first gen so there isnt alot of room to start with but there is a 4-1 that can fit possible the very very bendy one who makes it uhhhhh someone knows
-Roger
Guest
Posts: n/a
... anyone else have input?
yeah hi, question...why do you want a 4-1? cause it's all the rage? cause you want that extra 2-3hp with the benefits of possibly overheating? or do you want even less ground clearance? you want to spend $100 more? i mean c'mon, find me ONE good reason for a 4-1 in <u>THIS</u> situation...
who cares about a [croud oooohs]4-1 header[/croud aaaahs]. just find a deal on a 421. it will serve the same purpose but without all the bullshit to worry about in all the questions above. since this is a street car most likely, you're not ALWAYS gonna be up in the rpm where you would even benefit from the extra 2-3hp anyways. and if it's not a street car, you wouldn't be asking the question. you'd know the answer.
::raises hand:: over here.
ahhh i c the other muegn crx owner has joined our board.....IMO a b16 makes power up top anyway why not harness the power get the skid plate for the 4-1 and see how well ur clearance is u dont have to slam ur car like some people....its better for ur car not to be slammed any way.....and if u do lower the car lower it to where ur header is safe.....and good luck
go with a comptech header, performance wise its right up their with the 4-1 headers and is probably the best daily driver header out their(performance/quality wise). At most you'll have to bang the front crossmember in a bit, but I even doubt that.
keep in mind everybody this is a first gen crx not an ef body.
thanks for giving me the first opportunity to use this-
over heating? even with the header practically resting on the radiatior my car still operates at a normal temperature with no more than regular fan operation time. i dont even have water wetter in the car like i usually do right now. ground clearance could be an issue i you really have the car slammed and drive like an idiot. the toda header i use has excellent ground clearance (just slightly lower than the oil pan) and if you dont have the money to spend on that i belive that there are some good headers on the market that offer good ground clearance.
uhh he wants to.
thanks again for that)
Guest
Posts: n/a
and seriously, what's with the "if you can't afford toda" bullshit. are you trying to sound like a hotshot because you have a toda? well face it bud, you're driving a 1985 C-R-X. you don't sound cool to people when you explain to them that your header cost more than your car. just makes you look like an idiot. and again, i don't care what YOU paid for it, you're commenting as if you paid what toda thinks it's worth.
here's my DC that was on MY 87 Si...
if i had a better pic, i'd show you how much clearance i had with that. THAT header was tight in there. but let me tell you this...NOT ONE TIME was i driving this car, with the DC 421, did i think to myself "**** i should have bought a dope-*** looking 4-1 so that i could have picked up two horsepower at 7500rpm." 421s give plenty of clearance to the radiator, have plenty of ground clearance (not even an issue), make plenty power and work perfectly for what they're designed to do (which is outflow stock exh. manifold), so again...
find me ONE good reason for a 4-1 in THIS situation...
keep in mind, my 87 B20vtec would've eaten your "beast" 85 LSvtec alive...even with my 421! you ain't got ****.
fucken newbies.Guest
Posts: n/a
Are you saying that for a daily driver car, a 4-2-1 is better performance wise...
Am I right about the 4-2-1 giving you better midrange and torque, while the 4-1 gives you better top end?
How can the 4-1 sit lower than the 4-2-1?
oo = 4-2-1
OO
OO = 4=1
"keep in mind, my 87 B20vtec would've eaten your "beast" 85 LSvtec alive...even with my 421! you ain't got ****. fucken newbies."
you cant say that.. yeh and IF you still had your 87, every driver is different and every setup is different.. so for all you know he could beat you with his ls/vtec..
Hammed, what was your 87 b20 running??
I seen this car pull high 14s on a d16a1 that was 2 years or so ago I though that was a good time(also got it on tape too).. now he has this ls/vtec swap and i'm sure hes possibly 2 secs faster then he was before atleast..
E-Town4229, you dont know me but i saw your car a long time back when it was d16 powered at e-town import vs domestics and thought it was nice..
Ham'ed Hatch, I appreciate your strong feelings on the 4-2-1 but I really don't think its at all necessary to give the people who like 4-1 headers crap. I REALLY don't appreciate your comment at all that the header would cost more than the car. I think that was a real stupid remark. If you're going to offer your own opinions on the topic, and leave mine and the others out of it, then please continue to participate. But otherwise, go find yourself another thread because all you're doing here is making yourself look like a jackass.
Like I said before, with a car that weighs about 1700 lbs stock (if you don't beleive me, go here: http://www.autotrader.com/research/m...&ac_afflt=none , I am happy with the amount of torque the engine currently makes. I'm looking for top end power, which a 4-1 header does. I'm not planning on slamming the car, you can only lower the 85 CRX so much.
My next question, does the JDM 4-1 flow better than a DC 4-1? Anyone have dyno charts to prove it?
