How do you change a rear wheel bearing?
Old Jan 13, 2003 | 03:26 PM
shorti's Avatar
Default How do you change a rear wheel bearing?
as the topic states. what's needed to replace a rear wheel bearing and then how do i install it??
i have a 91 dx hb
thx
Old Jan 13, 2003 | 05:23 PM
shorti's Avatar
Default Re: How do you change a rear wheel bearing? (shorti)
bump
someone has to know
Old Jan 13, 2003 | 06:08 PM
keithv's Avatar
well to get to the bearing, you need to pull the drum off and take the shoes off as well. then you need to pop the metal cover on the hub to get to the nut holding the hub on. once the hub is off, you will most likely need the bearing to be pressed out.
i think that should do it.
Old Jan 13, 2003 | 06:17 PM
shorti's Avatar
Default Re: How do you change a rear wheel bearing? (breaka_1_9)
i was told that only the front bearings only need to be pressed out???
Old Jan 13, 2003 | 06:43 PM
primoEF's Avatar
for the rear you have to change the whole hub
Old Jan 13, 2003 | 06:50 PM
NCchris's Avatar
Default Re: How do you change a rear wheel bearing? (EFDog)
On drum brakes, just remove the wheel, then the drum. There is a nut and washer holding the hub on. Remove it and the hub will come off. Don't fool with the shoes unless they ned replacement. Press out the bearings and reinstall. I went to the junkyard and got another hub assy and so far it's lasted fine. No pressing bearings etc.
HTH
chris
Old Jan 14, 2003 | 06:05 AM
keithv's Avatar
Default Re: How do you change a rear wheel bearing? (NCchris)
thanks for the clarification! when i was doing the brakes on my GF's car, i removed the shoes to replace them and then removed the hub to get the wheel cylinder off. so i wasn't sure if you had to take off the shoes or not.
Old Jan 14, 2003 | 09:44 AM
brianbrannon's Avatar
pressed out or whacked with hammer. I change bearings all the time with just a hammer
Old Jan 14, 2003 | 10:53 AM
Ef Whore's Avatar
Default Re: How do you change a rear wheel bearing? (brianbrannon)
the shoes do not have to be removed---use the 32mm. axle nut socket you used to remove the hub to smack the bearings out with--I've been there my way works fine.
Old Jan 14, 2003 | 12:12 PM
7PSI CRX's Avatar
Default Re: How do you change a rear wheel bearing? (Ef *****)
The rear wheel bearing and hub are sold as a 1 piece unit.
About $75.00-$85.00 at your local auto parts.
Old Jan 14, 2003 | 12:22 PM
89civicdx's Avatar
Default Re: How do you change a rear wheel bearing? (7PSI CRX)
Its very easy to do just take off the nut ,pull off the hub and put on the new one...probaly one of the easiest jobs to do on the whole car.
MarkCayabyab
Oct 7, 2017 11:40 AM
PaChiLa Leader
Feb 18, 2009 05:21 PM
hondazccivic
10
Sep 15, 2008 05:07 AM
kornerk12
Jul 29, 2008 04:51 PM
DmcL
Nov 8, 2006 09:15 AM
