Greddy EVO catback=2 1/2 straight through?
Old Jan 13, 2003 | 01:46 PM
YellowR2000x2's Avatar
Default Greddy EVO catback=2 1/2 straight through?
So does anyone know if the Greddy evo b-pipe has any bottle necks? according to the website it lists the piping for the R as 60-70. i think 63.5 or so is 2.5in. so do those numbers mean that its 60mm at its smallest and 70mm at its largest or what? has anyone done any measurements on it or anything? just wondering how well it will work with my new setup...thanks for any info you guys can give me!
Old Jan 14, 2003 | 01:03 PM
Default Re: Greddy EVO catback=2 1/2 straight through? (YellowR2000x2)
any?
Old Jan 14, 2003 | 02:35 PM
Reid's Avatar
Global Moderator
The GSR catback can be ordered in 70mm.
Old Jan 14, 2003 | 03:19 PM
00MRSi's Avatar
Default Re: Greddy EVO catback=2 1/2 straight through? (Reid)
I thought the GReddy EVO exhaust was 60mm?
Old Jan 14, 2003 | 03:20 PM
Reid's Avatar
Global Moderator
Default Re: Greddy EVO catback=2 1/2 straight through? (00MRSi)
The GReddy EVO exhaust is 60mm for all standard Honda/Acura applications.
However the Greddy EVO can be ordered in 70mm for the GSR because Greddy also makes a turbo kit for that vehicle.
Old Jan 14, 2003 | 03:53 PM
00MRSi's Avatar
Ohhh.. Sounds good. Thanks for the info Reid. Does GReddy or "Trust" as known in JDM land make an N1 exhaust? I thought I saw a pic somewhere of a Trust N1 exhaust that was not available in the U.S..
Old Jan 14, 2003 | 03:55 PM
Reid's Avatar
Global Moderator
The Greddy Power Extreme 2 features a N1 style canister.
Reid - who awaits a paycheck from Greddy's advertising department...
Old Jan 14, 2003 | 04:22 PM
Malice's Avatar
New User
i remeber those pics of the greddy pe2 from awhile back. didnt have a bottleneck on the b-pipe?
Old Jan 14, 2003 | 05:47 PM
rodimus's Avatar
is that 2.5 inches..pardon my ignorance i'm too lazy to
look it up/find the conversion ...
do you know if it has any bottlenecks?
Old Jan 14, 2003 | 06:16 PM
underrated99si's Avatar
Well if the GSR can be ordered in 70mm cause of they make a turbo kit for it then do they make a SI one if so all you woudl need to do is modify the hangers and it would bolt right up to a ITR no prob
Old Jan 14, 2003 | 07:26 PM
mstewar's Avatar
Default Re: Greddy EVO catback=2 1/2 straight through? (underrated99si)
The GSR catback can be ordered in 70mm. Well if the GSR can be ordered in 70mm cause of they make a turbo kit for it then do they make a SI one if so all you woudl need to do is modify the hangers and it would bolt right up to a ITR no prob
Greddy tried to tell me that this WASN'T possible.. i had the canister portion of the EVO off my Si and wanted to use it with a custom B-pipe.. never happened.. I ended up just picking up one from the ITR that was wrecked and parted down in VA.. I have no idea if there were any gains from it for sure though, because I added my JDM 4-1 and carsound cat at the same time..
and FYI, by my ruler, the 60mm is just under 2.5 inches.. the 70mm is about 2 7/8's inches..
Old Jan 14, 2003 | 08:15 PM
SurferX's Avatar
Default Re: Greddy EVO catback=2 1/2 straight through? (mstewar)
60mm=2.36"
70mm=2.76"
I called Greddy a long time ago on this and they told me that it is just 60mm, stepping up to 70mm at the muffler. They made no mention of a seperate full 70mm application.
Old Mar 31, 2004 | 03:53 PM
KetteringITR's Avatar
I cant find the Greddy PE 2 for a 2001 Type R anywhere. Can anyone help me out with some links? And does anybody have any thoughts on the system?
Hazeburner
Honda Civic (2006 - 2015)
Sep 7, 2006 07:13 AM
drSquish
Jun 3, 2005 10:19 PM
turbolag98
Oct 25, 2003 04:29 PM
bowhunter
Feb 25, 2003 06:01 PM
