D16Z6 Distributor installation
Old Jan 13, 2003 | 12:43 PM
spike's Avatar
Default D16Z6 Distributor installation
I recently installed a distributor in a D16Z6 motor.. the distributor could only be installed one way, however the part that gets inserted into the head was a circle with two square posts on it. It could be inserted one way or 180 degrees the other. the car will not start now.. could we have installed it backwards?
I also understand that in a 4 stroke engine the spark plug only fires every other time the piston comes up.. is this correct? We checked to make sure the #1 piston was in the TDC position when the rotor in the dist. cap was at the #1 position. thanks for any help
Old Jan 13, 2003 | 01:44 PM
Chiovnidca's Avatar
Default Re: D16Z6 Distributor installation (spike)
If you take a closer look at the "two square posts" you'll see that they are offset to one side a little. It should only fit one way, but they can be forced in the wrong way. (bad)
Old Jan 13, 2003 | 02:50 PM
ImportHatch's Avatar
Default Re: D16Z6 Distributor installation (Chiovnidca)
Yes it is sllightly offset. Look closely at it. My buddy forced his one backwards by accident on his zc, luckily it didnt damage anything. Just recheck it.
Yager-
95civicLS
May 5, 2010 08:13 AM
taterbug
Jan 8, 2009 06:14 PM
Import13alla
Apr 9, 2004 06:24 PM
HarryB
Aug 13, 2002 09:13 AM
