Tokico Illuminas adjust knob
Old Jan 13, 2003 | 11:28 AM
puhlode's Avatar
Default Tokico Illuminas adjust ****
I just bought some gently used illuminas, but they didn't come with the adjustment **** on the top (front shocks).
a) would pliers work fine for adjustment?
b) Since i don't have the ****, i don't know... is stiffer clockwise, or counterclockwise?
c) where could i get replacement *****?
Thanks.
Old Jan 13, 2003 | 12:30 PM
JHill's Avatar
Default Re: Tokico Illuminas adjust **** (puhlode)
Thanks.
a)no, pliers won't reach deep enough into the hole in the top of the shaft.
b)They have 5 positions, which give a little click when you are in one. It goes around infinitely, 1-2-3-4-5-1-2-3...
1 is least resistance to 5 being the most
call Tokico or ask a Tokico dealer for parts.
http://www.tokicogasshocks.com
[Modified by JHill, 1:31 PM 1/13/2003]
Old Jan 13, 2003 | 03:43 PM
puhlode's Avatar
Default Re: Tokico Illuminas adjust **** (JHill)
[QUOTE]
Is more resistance clockwise or anti-clockwise?
Old Jan 15, 2003 | 06:36 AM
JHill's Avatar
I think it it more resistance clockwise. The thing about it is: say it is on 3 right now, you go clockwise two clicks and are at 5, you go clockwise one more click and you're back at one. It just keeps going around again and again. It would be safer to say a certain "clock" position equates to a shock setting.
Old Jan 15, 2003 | 10:49 PM
speed's Avatar
Try this...Turn the shaft with what ever you can reach it with.Turn it counter clockwise and at each "click" push down on the car.you will know when you get to the 1-5 spot when you can bounce the car easily and then on the next counter clockwise "click" youcan barely push the car down......Also it doesn't matter which way you turn the shaft normally the settings are 1-2-3-4-5-1-2-3-4-5.....It's just easier to tell initially by turning counterclockwise to find that "5-1" click.Hope this helps
Old Jan 16, 2003 | 06:48 AM
brwnrice's Avatar
Default Re: Tokico Illuminas adjust **** (speed)
call tokico and ask them for a new ****. they should be able to give it to you for free.
Old Jan 16, 2003 | 08:31 AM
PhatOptimo's Avatar
Default Re: Tokico Illuminas adjust **** (brwnrice)
I have herd they are good about this.
fergs96integra
Oct 12, 2009 03:02 PM
kevpotts
Suspension & Brakes
Aug 17, 2007 02:39 PM
$ISELLTOU4LESS$
Jul 19, 2006 10:55 AM
puhlode
Jan 14, 2003 02:36 PM
CoolKat
Aug 8, 2002 01:09 PM
