Long Term Effects from Lowering
Old Jan 13, 2003 | 10:31 AM
JackAcc's Avatar
Default Long Term Effects from Lowering
My accord is the 1st lowered car I have owned. I love the way it feels, the way it looks, and the way other people drool over it. I've vowed to drop every car I drive in the future...(although I hope my Accord lasts for at least another 10 years)
Can anyone tell me of any long term effects I may run into having a dropped car? Any horror stories?? Anything I should check regularly? I live in FL so I usually have a smooth ride. But I'm moving back to NJ next year so I anticipate being bounced around a bit more. I just want to make sure I take care of it the right way. Thanks!!
Old Jan 13, 2003 | 10:32 AM
KTeller8's Avatar
Default Re: Long Term Effects from Lowering (JackAcc)
tires, alignment and camber wear
Old Jan 13, 2003 | 10:38 AM
JackAcc's Avatar
Default Re: Long Term Effects from Lowering (KTeller8)
I have a camber kit on there so I am hoping the tires will not be a problem. I was more worried about engine components (or any other main components) being jolted more than usual with the stiffer suspension.
I heard that CV joints can wear out faster and that the chassis takes more of a beating and could crack as well as the suspension components... Maybe motor mounts cracking? I'm sure alot of this stuff is put out there just as a warning and sort of a disclaimer but I am wondering if anyonoe has actually had these things happen?
Old Jan 13, 2003 | 10:39 AM
paul9luap's Avatar
agree with CV joints.
EDIT: obviously tire wear unless you have a camber kit.
[Modified by paul9luap, 2:40 PM 1/13/2003]
Old Jan 13, 2003 | 11:58 AM
JackAcc's Avatar
Default Re: Long Term Effects from Lowering (paul9luap)
How do you know when your CV joints are worn? Do you know offhand how much they are to replace??
Old Jan 13, 2003 | 12:03 PM
ArchAngel Sabastian's Avatar
New User
nice avatar
CV joints if you do the work your self (easy) 100bux or less for the CV and then it depends on what you have for tools.
Old Jan 13, 2003 | 12:09 PM
urbanlegend21's Avatar
New User
Default Re: Long Term Effects from Lowering (ArchAngel Sabastian)
generally CV joints will not wear that fast if not lowered to far, if you have one go bad look at the wear pattern on the cup, if it does not generally stay in the middle of the cup then you have a problem
if you wanna know if they are gonna wear then look at the boot, if it is obvious the ribs of the boot are rubbing together becasue of an excessive angle on the shaft then I suggest raising the car
do not buy rebuilt axles either, the process they use creates shorter life spans for axles, especially stressed axles
visit http://www.RAXLES.com with your concerns, Mardi will be able to better explain, and they build high quality axles for very good prices
Nick M's Avatar
they click when they are bad, also if there is alot of grease on your inner wheel you may have ripped a cv boot and the lack of grease can lead to CV joints going bad prematurely
Old Jan 13, 2003 | 02:07 PM
JackAcc's Avatar
Default Re: Long Term Effects from Lowering (Nick M)
Thanks for the info guys!!
Old Jan 13, 2003 | 02:22 PM
Canonm7's Avatar
http://www.driveshaftshop.com also.
Hey man, I'm in NJ myself. What part are you moving to?
Old Jan 13, 2003 | 03:39 PM
JackAcc's Avatar
Default Re: Long Term Effects from Lowering (Canonm7)
Not sure yet. Originally from Clinton, probably move somewhere between there and NYC. Where you at?
Accord-Guy
Suspension & Brakes
10
Apr 20, 2008 08:54 PM
nikker
Feb 18, 2006 07:59 PM
OdysseyHF
Nov 29, 2003 07:25 AM
AccordVtec
Jan 4, 2003 08:41 PM
99DXcoupe
Sep 27, 2002 09:35 PM
