question about code being thrown....
I believe the code read misfiring cylinder/piston. I was told when you lower compression that this code will get thrown. If not, i'm not sure what is the problem causing this. Hopefully it's just a misfiring plug and not something to serious.
Thanks
Thanks
No idea what code your throwing however, it could be detonation.
Suggest you lower the boost and check the plugs and wires before doing anything crazy.
I'm almost 100% sure it's not detonation. Only running 10psi @ 9.1:1. I will check the plugs though, I haven't changed them yet and that could be the problem. Thanks for your reply.
