tried a search but there is no info on CODE 13!!
Old Jan 13, 2003 | 03:38 AM
93eg-EKhybrid's Avatar
Default tried a search but there is no info on CODE 13!!
Hey guys my car is doing the 1 long blink and 13 short blinks (89 STD). I looked in search but found nothing about a code 13. I see it is the atmospheric pressure sensor but where is it, how expensive, and what does it do??
Old Jan 13, 2003 | 07:07 AM
Jaker's Avatar
Default Re: tried a search but there is no info on CODE 13!! (89B16HB)
You would not be getting 13 short blinks. You may be reading the codes incorrectly. 13 would be 1 long blink, and 3 short ones.
Look here for all the codes:
http://hybrid2.honda-perf.org/tech/codes.html
The atmospheric pressure sensor is inside the ECU, and is part of the circuit board.
Old Jan 13, 2003 | 10:59 AM
Default Re: tried a search but there is no info on CODE 13!! (Jaker)
this is what it does now:
blink blink blink blink blink blink blink blink blink blink blink blink blink
it does that over and over again.
Old Jan 13, 2003 | 11:14 AM
TypeR0207's Avatar
You have TWO codes going if you get one blink, then 13 ..............
1 blink is emission/02 sensor.
Don't know what 13 blinks is.
The EF dosn't do two separate blinks for one code. It beeps continuously and you just have to count them.
I currently had one blink, then 16 blinks. Which was emissions, and injectors.
Old Jan 13, 2003 | 12:27 PM
zCivic's Avatar
Default Re: tried a search but there is no info on CODE 13!! (TypeR0207)
Could it be a code 10 for the long and then 13 short flashes.
Code 10 is the Intake air temp sensor and code 13 for Baro sensor.
The IAT is on the intake manifold. The Baro sensor is on the passenger side kick panel. Its kind odd shaped has 1 bolt thru it to hold it in place and has a 3 pin connector which is upside down T shaped. Have you messed with you ECU pins at all, I had a problem where they wasn't making full contact and threw everything off whack
Old Jan 13, 2003 | 03:01 PM
Default Re: tried a search but there is no info on CODE 13!! (zCivic)
I had thrown a D15B2 ecu in there for a day and then switched back to my D15B1 ecu.
It blinks 13 times ause: 13 times ause: etc.
Old Jan 13, 2003 | 03:22 PM
Jared's Avatar
code 13 for Baro sensor. The Baro sensor is on the passenger side kick panel. Its kind odd shaped has 1 bolt thru it to hold it in place and has a 3 pin connector which is upside down T shaped. Have you messed with you ECU pins at all, I had a problem where they wasn't making full contact and threw everything off whack
sounds like this is your problem
Old Jan 13, 2003 | 03:28 PM
Default Re: tried a search but there is no info on CODE 13!! (Jared)
Anybody know how much one is gonna run for??
Old Jan 14, 2003 | 04:16 AM
zCivic's Avatar
I have an xtra one. Will let you get it cheeply. I also have the helms manual if you want to test it with a multi-meter. I thought mine was bad but it was the ECU pin outs got messed up. I you need one im/post here and let me know.
Old Jan 14, 2003 | 05:37 AM
I might need it. If my prelude doesn't have one on it then I will buy yours, so shoot me an email or a PM and let me know what you want for it.
strider380
Nov 15, 2010 07:39 AM
Tru_Shine
Aug 12, 2009 03:58 PM
GsrVtec
Oct 19, 2006 07:33 AM
FitCRX
Sep 1, 2002 04:24 PM
