Gsr oil pan!
Its very easy to change ive hand mine off and on at least 7 - 8 times. All you do is take off all the bolt around the oil pan, and there are two bigger bolts that bolt to the tranny take them off and pull the cover off that goes over the fly wheel and then you can access the last 3 bolt and there you have it.
Also a dented oil pan could be bad depending on where the dent is and how bad it is. The dent could prevent the oil sump from getting oil and therefor the engine would not get the proper amont of oil.
Also you need to take you header or downpipe (if your turbo) off also.
[Modified by BVM, 7:00 AM 1/13/2003]
OEM is probably fine. If you want to step up to a baffled oil pan that would be great too. They pretty much all do the same thing (Mugen, Spoon, J's, etc...)
