getting hondata???
Old Jan 12, 2003 | 06:58 PM
xXx Justin xXx's Avatar
Default getting hondata???
i want to get a hondata setup for boost. going on d16z6. have a greddy kit, planning to run about 9 psi w/ dsm 450's. resistor box, 2 1/2" cat back, high flow cat, and maybe a custom 2 1/2" downpipe. which stage or model would be best for me? and also is it a new ecu setup, or will i have have to do something to my p28 as well? just wondering if i will be out of a car while the hondata is being done. also i plan on getting a boost controller before all the turbo stuff goes in. thanks.
[Modified by SOHC Beast, 4:00 AM 1/13/2003]
Old Jan 12, 2003 | 07:01 PM
paulzy's Avatar
Default Re: getting hondata??? (SOHC Beast)
http://www.hondata.com
Old Jan 12, 2003 | 07:07 PM
ekb18c's Avatar
You will have to send out your p28 to a hondata dealer to have it chipped. s100 with boost should be fine for you. If you send out your ecu to me, I can chip it out for you and I will inlude a START UP map for you. With the start up map you can drive your car to the nearest tuner so they can tune your car.
HTH
Old Jan 12, 2003 | 07:35 PM
Default Re: getting hondata??? (ekb18c)
how much for you to chip it? and will i still have a rev limiter? if not what do i need to buy so i can have a rev limiter, 1st gear spins and kicks up way too damn fast to not have a rev limiter......and so if you chip it with that start up deal...(which i need) and i buy the s100 setup... i'd be straight? i get all wires and everything to plug it all in? not sure exactly how the hondata setup gets pluged in, but i'm sure i will get instructions, or it won't be too difficult. let me know about pricing for u to chip it, what you change when chipped, and how long it would take.. thanks
Old Jan 12, 2003 | 07:38 PM
ekb18c's Avatar
The whole process for me to chip the computer takes about 1 hour to do. Yes, there is a rev limiter on the ecu. It's whatever I set it up to be. So you tell me what rev limiter you want, but most of the time i leave it on the stock rev limiter. Once i send it back to you, all you have to do is plug the ecu back into your harness and it should start right up.
Old Jan 12, 2003 | 07:53 PM
well i just read up on the s100 w/boost. sounds good. it says it goes inside the ecu... so am i supposed to get the hondata thing, then send you that and the ecu, and you install all that crap? and yes, i like the stcok rev limiter for now, maybe higher after i get some head work done...and how much do u charge to do all this?
Old Jan 12, 2003 | 08:08 PM
98civicEX's Avatar
colin of rpmnyc gets , i bought pistons from him prior. you're in good hands w/ this guy!
spoonhatchblack
Dec 12, 2008 11:28 PM
street_bliss
May 10, 2007 09:24 AM
johnnylaw
Oct 1, 2005 04:53 PM
