getting hondata???
i want to get a hondata setup for boost. going on d16z6. have a greddy kit, planning to run about 9 psi w/ dsm 450's. resistor box, 2 1/2" cat back, high flow cat, and maybe a custom 2 1/2" downpipe. which stage or model would be best for me? and also is it a new ecu setup, or will i have have to do something to my p28 as well? just wondering if i will be out of a car while the hondata is being done. also i plan on getting a boost controller before all the turbo stuff goes in. thanks.
[Modified by SOHC Beast, 4:00 AM 1/13/2003]
You will have to send out your p28 to a hondata dealer to have it chipped. s100 with boost should be fine for you. If you send out your ecu to me, I can chip it out for you and I will inlude a START UP map for you. With the start up map you can drive your car to the nearest tuner so they can tune your car.
HTH
HTH
how much for you to chip it? and will i still have a rev limiter? if not what do i need to buy so i can have a rev limiter, 1st gear spins and kicks up way too damn fast to not have a rev limiter......and so if you chip it with that start up deal...(which i need) and i buy the s100 setup... i'd be straight? i get all wires and everything to plug it all in? not sure exactly how the hondata setup gets pluged in, but i'm sure i will get instructions, or it won't be too difficult. let me know about pricing for u to chip it, what you change when chipped, and how long it would take.. thanks
The whole process for me to chip the computer takes about 1 hour to do. Yes, there is a rev limiter on the ecu. It's whatever I set it up to be. So you tell me what rev limiter you want, but most of the time i leave it on the stock rev limiter. Once i send it back to you, all you have to do is plug the ecu back into your harness and it should start right up.
well i just read up on the s100 w/boost. sounds good. it says it goes inside the ecu... so am i supposed to get the hondata thing, then send you that and the ecu, and you install all that crap? and yes, i like the stcok rev limiter for now, maybe higher after i get some head work done...and how much do u charge to do all this?
spoonhatchblack
Dec 12, 2008 11:28 PM
street_bliss
May 10, 2007 09:24 AM
