car over heating...
Old Jan 12, 2003 | 04:45 PM
91HATCH's Avatar
Default car over heating...
car was overheating and the fan was on...i turned off the car and later started the car again...car began to overheat again but this time the fan doesn't kick on...whats the problem here?
Old Jan 12, 2003 | 05:56 PM
Quik89Si's Avatar
Default Re: car over heating... (91HATCH)
1st step...check the radiator cap and all seals upon said cap - if seals are bad, car will overheat.
2nd step...further describe circumstances so that we can get a better idea of why this is happening.
3rd step...SEARCH and see if you can find help.
Alex
Old Jan 12, 2003 | 06:15 PM
MADEINIRAQ's Avatar
Default Re: car over heating... (Quik89Si)
4. check coolant.
5. check thermostat
6. give up and sell car
Old Jan 12, 2003 | 06:18 PM
Quik89Si's Avatar
Default Re: car over heating... (madeiniraq)
I knew I forgot a step
Alex
Old Jan 12, 2003 | 07:47 PM
tmai246's Avatar
It could possibly be your head gasket. Check your coolant reservoir and if there is black oil residue in it, then you will need to get your head gasket replaced. Also, does your car's exhaust look white/blue. This is another indication of a blown head gasket. It cost me about $500 to get this replaced at the dealer.
Old Jan 13, 2003 | 12:20 AM
7PSI CRX's Avatar
To answer your question.......
Little or no coolant left.
I bet there was no heat either.........
Old Jan 13, 2003 | 03:25 AM
ThatRicerDaniel's Avatar
hit me up hatch . nitrousdreamz@hotmail.com . your local ill help you out.
BlackShingo
May 6, 2010 03:56 PM
oaklandwilly
Other Make Vehicles
Jul 27, 2009 08:10 PM
93eh2hatch
27
Dec 19, 2007 03:02 AM
Dj^BaNNeD
Feb 10, 2007 04:22 PM
Bobby808
Apr 27, 2005 11:22 AM
