Cam Gear Install Question
Old Jan 12, 2003 | 04:30 PM
acatak's Avatar
Default Cam Gear Install Question
Im installing ITR cams and skunk 2 cam gears soon and I was wondering how hard is it to get the bolt off of the Cam Gear. I have an impact wrenchg so will I need that to get it off? Also, do I need the impact wrench for any other part of the install. I want to do the install without loosening the tensior bolt. I want to just slide one cam and gear out at a time, and keep the timing belt around the other cam gear so it doesnt move any teeth. Thanks for your help.
Old Jan 12, 2003 | 04:39 PM
cheezthis's Avatar
Default Re: Cam Gear Install Question (acatak)
Hmm...we needed power tools to remove the cam gear from the cam.
As for that method of removing one at a time...never tried it. However, I can tell you that putting the timing belt back on without loosening the tensioner is a royal pain. I say loosen the belt, it's not hard to tighten back up, just make sure everything is at TDC.
Old Jan 12, 2003 | 05:04 PM
acatak's Avatar
Default Re: Cam Gear Install Question (cheezthis)
How do you know how much to tighten it?? Ive just heard alot of people being 1-2 teeth off and I am worried about it... What else to do I have to remove/loosen to get to the tensior belt. I kno Dlo gsr did his without loosening the tensior bolt and his came out fine.
Old Jan 12, 2003 | 05:23 PM
cheezthis's Avatar
Use a marker to mark the teeth on your belt before you remove it...no teeth problems.
I don't remember everything on how to loosen the belt, but loosening the power steering pulley helped a bit.
You can change your cams without doing loosening the belt, but I personally find it to be a pain...and have seen people hack up their cam gears a bit when putting them back on.
If you don't have a helms manual, get one now...that will answer most of your questions and more on this.
Old Jan 12, 2003 | 05:30 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i just had a heavy vise, wrapped the cam in a towel, had my friend hodlt he vise down and used a torque wrench. worked like a charm
DMCCOY
12
Jan 9, 2009 08:39 PM
carbonek9
Mar 2, 2006 11:13 PM
EJ8tunerman
Jun 21, 2005 04:35 PM
stevieteg
May 10, 2005 09:50 AM
REDBARON
Feb 26, 2002 11:12 AM
