SOHC wiring problem??
Old Jan 12, 2003 | 04:24 PM
XzzYzzX's Avatar
Default SOHC wiring problem??
I just put a 95 sohc vtec si motor in my 95 civic hatch but the guy who hook it up used a MSD rpm switch for my vtec on my stock ecu but it doesn't feel like vtec is pulling i have a p28 and i wanna run it how do it do this? Thanks for your help.... Its for my friends car....
[Modified by XzzYzzX, 8:25 PM 1/12/2003]
Old Jan 13, 2003 | 10:55 AM
XzzYzzX's Avatar
Default Re: SOHC wiring problem?? (XzzYzzX)
Anybody??
Old Jan 13, 2003 | 11:00 AM
Spade's Avatar
Image courtesy of Katman.
eg6ajk's Avatar
http://tech.hybridgarage.com/tech/5gtech/index.html
just skip on the knock and the EVAP, and secondaries, the rest will apply
more indepth
http://hybrid2.honda-perf.org/tech/wiring/wiring01.gif
http://hybrid2.honda-perf.org/tech/wiring/wiring02.gif
Old Jan 13, 2003 | 02:34 PM
XzzYzzX's Avatar
Default Re: SOHC wiring problem?? (eg6ajk)
Is that the same even though its a single cam vtec motor??
Old Jan 13, 2003 | 02:55 PM
lonefuzzy79's Avatar
I started doing this this weekend I have done the same swap and do the wiring it makes a WORLD of difference, you will find all kinds of power and driveability. Two ways you can do it. Find the wires that lead from the VTEC sensor (Green with Yellow stripe) the Oil Pressure sensor (Blue with black stripe) and the Knowck sensor (havn't got there yet) and wire from the ECU to the left side plug (plugs the chassis wiring into the engine wiring) I am assuming you kept your chassis harness so you will have to run a wire from the ECU to this point as there are no corresponding wires in the chassis harness (still with me?). Or you can just find all three sensors, splice in wires and run them straight to the ECU. Does that help? Use the above diagram that the dude posted and use the red colored pins, should work just fine. Good luck.
bseriescrxsi
Sep 30, 2020 04:27 PM
Dan222000
20
Feb 26, 2012 02:53 PM
Nicaraguense13
11
May 12, 2006 09:49 AM
hondaacura94
Dec 12, 2003 04:29 PM
