90 Accord 4 Door H22 Problem......
Old Jan 12, 2003 | 03:15 PM
AccordVtec's Avatar
Default 90 Accord 4 Door H22 Problem......
I have a 1990 Honda Accord Lx with JDM H22.
I put it away for the winter, and this weekend I went to take it out for a quick little spin.
For some reason my VTEC wasnt working.
What are the first tghings I check to confirm my problem.
Also, PLEASE TELL ME HOW TO POST PICS, ITS KILLING ME!!!!!!!
Thanks
Accord VTEC
Old Jan 12, 2003 | 11:41 PM
scrubachu's Avatar
Default Re: 90 Accord 4 Door H22 Problem...... (AccordVtec)
did you let the car warm up? for vtec to work, the car has to build up enough oil pressure i believe. i know for a fact that vtec wont work unless the car is warmed up though. hope this helps
Old Jan 13, 2003 | 05:23 AM
Stew Pidasso's Avatar
Default Re: 90 Accord 4 Door H22 Problem...... (scrubachu)
I have gotten in my car started it and pulled out of the driveway. I put the throttle down and I hit vtec. No warm up was necessary. The car should have high enough pressure after the car has been running a few seconds. This was on a 94 Accord EX though. Not sure if it's the same on an H22a. Could it be the vtec solenoid sticking perhaps? Was the oil level full?
Old Jan 13, 2003 | 06:25 AM
2point6's Avatar
Default Re: 90 Accord 4 Door H22 Problem...... (Stew Pidasso)
Stew, It is most likely that you can roll into VTEC before warm-up because you have a VAFC. If he doesn't the car will have to warm up first.
Also, AccordVtec Is your engine stock?
[Modified by 2point6, 7:26 AM 1/13/2003]
Old Jan 13, 2003 | 06:42 AM
Default Re: 90 Accord 4 Door H22 Problem...... (2point6)
Aha I see. Is this bad for the engine to get into vtec before it's fully warmed? This was a warm summer day keep in mind.
Old Jan 13, 2003 | 06:55 AM
2point6's Avatar
Honestly, I would wait until the car is up to operating temp (or close to it) before going into VTEC. Honda put that safeguard into their ECU programming and the addition of VTEC controllers bypasses the ECU in the VTEC engagement function.
Old Jan 13, 2003 | 08:55 AM
Hmm, I never really thought about it. Thanks for the info.
AccordVtec
How to post pics...
1) Upload the pictures to a web-server (i.e http://www.we-todd-did-racing.com)
2) Once the pictures are loaded, Click the picture to retreive it
3) Right click and then click PROPERTIES
4) Copy link
5) Paste the URL in between the [img][/img]
Old Jan 13, 2003 | 10:30 AM
4doorH22's Avatar
The cam lobes won't switch when coolant/cylinder head/engine is cold or when oil pressure is less than ~30 PSI. If there's anything wrong with the VTEC solenoid or signal wire, it should throw a CEL.
red_fangz
Jul 19, 2012 10:50 AM
The(704)kid
Jul 5, 2011 10:19 PM
SPOON_FED_DC_2
Apr 17, 2005 01:50 PM
jdm1
May 9, 2004 09:03 PM
RHEMU
Aug 13, 2003 02:38 PM
