Problem with low beam headlights. (Did search through 7+ pages) Please help
All of my electrical systems in my crx have worked great since I purchased the car during Halloween. Then yesterday I turn on the headlight switch and the foglights and corners turn on, but the headlights do not. My foglights are wired into the low beam switch. I turn on the brights and they work. I have a jdm front end with h4 bulbs on my crx. I checked all of the fuses under the dash and all of the fuses under the hood and they are in good condition. Do you all have any other ideas? Thanks
your wiring sounds like its jacked. check all your connections then check the bulbs. do the high beams work?
Blaze
Blaze
