ITR Radio
plugs right in, unlike my 00 SI radio, the ITR kept the audio plug from the 92-95civic which is
and it lites up amber so it goes will SIR interior parts.
It does not sit flush and does not look stock since it is black and the dash is gray. It does not look bad though. I don't know how many watts but it is nothing big since it is a stock deck.
everything plugs right in.. i had a teg radio in my sol before i put in the prelude radio.. plus im a mobile electronics installer.. and i see them all the time.. and its all the same ****.. most honda radios excluding the newer ones are all the same size and have the same exact bolt/screw holes.. in 98 most of the hondas did change plugs though... although the integras did not... and even if the plugs are different you can go down to your local best buy and buy a conversion harness... it will be $15.99 for the harness that plugs into the factory plug.. and then another $15.99 for the new factory plug.. (its 34.22 with tax) and then you just wire both harnesses color to color (red to red... yellow to yellow.. etc) and then you plug on side into your regular civic harness.. and then the other side into the newer honda radio.. here is a makshift picture of like a 95 honda harness converted to a 98+ honda harness (but remember the integra radios all the way up to 2001 were all the old harness) its ghetto but thats ok...
[Modified by 95DelSolSI, 10:55 PM 1/12/2003]
the bolts dont line up shaggy... take off the lower console
i put a thin thin thin zip tie through the radios vent holes, wrapped it around the center console frame, and put the center console back on. works fine.
rig somethin sucka
rig somethin sucka
then you are doing something wrong.. it fits.. and the bolt holes do line up... i tried it in my friends civic this morning with my old teg radio.. also here is a pic of it in my del sol.. all bolted in with factory bolt holes..
[Modified by 95DelSolSI, 10:56 AM 1/13/2003]
BlueIntegraBoy
Mar 19, 2005 11:03 AM
UnrealSpeed
11
May 28, 2003 06:42 AM
