Resetting SRS Light in 5G
Old Jan 12, 2003 | 11:07 AM
ace1875's Avatar
Default Resetting SRS Light in 5G
Ok I was searching and i found this for 7th G What i want to know is that does it also apply to 5Gs My SRS light came on It doesn't bother me but my mom thinks it going to exploed in her face
How to reset your SRS light on your civic. This works for 99-00 Civic's as well as 2k1's. What is pictured is actually a 2k1 but the plug for the 99-00's are in the fuse box also, just on the other side of the column.
1st you need to either buy or make the "SCS Service Connector." I used a speaker harness for and older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly.
2nd you need to find the MES (Memory Erase Signal) connector which is pictured below:
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
Plz help
[Modified by ace1875, 8:20 PM 1/12/2003]
Old Jan 12, 2003 | 11:22 AM
ace1875's Avatar
Default Re: Resetting SRS Light in 5G (ace1875)
bump!
Old Jan 12, 2003 | 12:07 PM
b19coupe's Avatar
Same procedure works for 5th gen, but if there is an underlying cause that keeps causing the SRS light to come on, you will have to have that repaired.
Old Jan 12, 2003 | 12:44 PM
HXMan's Avatar
It works...I just did it on mine.
dogpile5
156
Oct 4, 2017 11:04 AM
n2civicsi
Jan 15, 2006 10:32 PM
777sC
Jul 16, 2004 11:55 AM
boredracer408
Feb 2, 2004 05:17 AM
