5th gen h22a swap question
Old Jan 11, 2003 | 11:12 PM
Cm91h22a's Avatar
Default 5th gen h22a swap question
I'm helping to do a jdm h22a in a 95 accord. the question i have is abuot the distributer on the h22 that has an internal coil like the obd2 usdm h22 with 2 connectors, 7 wire and 2 wire. the original harness from the f22 only has 1 harness for the distributer which has only 5 wires and another harness which goes to the timing cover and eventually to a cranksensor that has 4 wires. which wires from the crank sensor need to be rewired into the h22a distributer or is there a wiring diagram that anyone can help me with. any info will be helpful. Thanks
Clyde
Old Jan 16, 2003 | 12:44 AM
AsiAnVenOm's Avatar
Default Re: 5th gen h22a swap question (Cm91h22a)
you dont need to rewire anything...the F distributor should also has two plug...2 wires and 5 wires...cuz when i did my swap...it plugs right up with my accord harness..
Old Jan 18, 2003 | 10:03 PM
Jago's Avatar
Default Re: 5th gen h22a swap question (AsiAnVenOm)
My swap came with everthing cut. I just wiried
everthing to the f22 harness.
tkhang
Aug 31, 2010 03:14 PM
jinxster
May 30, 2003 11:46 AM
