for those with gsr seats in their CRX...
Old Jan 11, 2003 | 09:23 PM
rasta420's Avatar
Default for those with gsr seats in their CRX...
im trying to swap my CRX Si seats out for these 2001 gsr leather seats that i got. i searched on the topic and tried to swap the outer rails like one thread said. but the holes for outer rail on the CRX don't match up with the holes on the GSR seat! they are like half a centimeter apart. should i just drill through the mounting location on the gsr seat?
how did you guys do the seat install?
im just trying to swap outer rails, and mount it down with three matching bolts, like the thread said. any ideas, tips?
Old Jan 11, 2003 | 09:42 PM
crx8psi's Avatar
Default Re: for those with gsr seats in their CRX... (rasta420)
I did mine the cheaters way sat the seat even where i wanted it and drilled new holes in the floor and where it didnt sit flush i put washers or nots as spacers and then put nuts underneath the car to hold them in. Like I said i did it the cheaters way
Old Jan 11, 2003 | 10:17 PM
jdmWONG's Avatar
Default Re: for those with gsr seats in their CRX... (b16a88hatch)
I bolted mine straight to the floor. you sit really high if you use the seat rails. I love the way the seats sit now.
Old Jan 12, 2003 | 06:03 AM
rasta420's Avatar
Default Re: for those with gsr seats in their CRX... (Blow'N'CRX)
so you used the gsr seat rails? didnt it sit unevenly? did you bend the metal on the seat rail at all?
Old Jan 12, 2003 | 11:46 AM
jdmWONG's Avatar
if you use gsr seat rails it will sit uneven. You can rig it up so it works but it sits too high. i could open my sunroof and sit up staight and look out the top of my car while i was driving. I bent my rails up and made custom brackets so all four bolt holes lined up and it sat even, but i wasnt happy with my head touching the roof when i drove, so i now bolted them to the floor, with no seat rails at all,sits perfect, cant move the seat back or forward, but i dont care now only people about my height can drive my car.
Old Jan 12, 2003 | 12:47 PM
rasta420's Avatar
well im pretty short, about 5'7'' so i dont think ill have the problem of my head touching the ceiling. anyone else have a better idea? should i just punch out a hole to bolt the outer CRX seat rail onto the gsr seat, then use three bolts to hold it down? will the seat at least be even this way?
Old Jan 12, 2003 | 02:26 PM
rasta420's Avatar
well been drilling out the mounting location on the front of the outer seat rail so the CRX outer seat rail can fit.
i stopped and i measured the distance in between the front bolts in the car, and its between 15-16 inches...and the distance in between front bolts on the GSR seat is like 18 inches! what should i do?
Old Jan 12, 2003 | 05:49 PM
CRXSIFUEL's Avatar
no no no
ghetto rig ahhhhhhhhhhhhhhhhhhhh
i got 01 itr seats in my rex bolted up
basically u use your crx bottom pan, wraped in the gsr leather and plush along with the crx hinges and the gsr tops, i cut and rewelded my hinges to make the seat less reclined (teg seats + crx hinges = reclined like a homie seat)
they fit good and feel good, IM me for more info
Old Jan 12, 2003 | 08:46 PM
rasta420's Avatar
Default Re: for those with gsr seats in their CRX... (CRXSIFUEL)
having trouble getting the top bolt off of the GSR recliner - pulled the zippers, but the bolt is way up on the upper part of the seat covered by the plush/leather...
HELP!
jdmcrx1819
Jul 8, 2011 03:06 PM
cor4ey
Jan 1, 2009 02:15 PM
Teckademic
Sep 25, 2004 06:35 AM
xXx Justin xXx
Oct 28, 2002 07:25 PM
HarryB
15
Jun 23, 2002 10:31 PM
