Pirelli PZero Assimetrico?
Old Jan 11, 2003 | 06:24 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Pirelli PZero Assimetrico?
They are only $50 in 195/50 on tirerack.com. 140 treadwear and seem to have pretty good grip. Since these are so cheap would they be good as a time trial tire for a beginner with little money? I have two sets of rims and was thinking of running them on the track and keeping my SO-3's for the street. Any opinions?
Old Jan 11, 2003 | 06:28 PM
uNF$@#!'s Avatar
Default Re: Pirelli PZero Assimetrico? (ActiveAero)
those arent cheap for 15" rubbers. given the tread wear dont expect more than about 5000 miles from them.
Old Jan 11, 2003 | 06:31 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Pirelli PZero Assimetrico? (Soup ****)
Then what is cheap for 15" tires? I thought my SO-3's were a steal for $79 each.
Old Jan 11, 2003 | 06:35 PM
uNF$@#!'s Avatar
cheap is a tire that grips well, and lasts a long time, which your pzeros probably wont
i think the stock re010's have a longer life time than 125.
Old Jan 11, 2003 | 06:36 PM
pleiades nutz's Avatar
Here's a reveiw on the 16 PZero Asimmetrico courtesy of itrsport.com: http://12.239.16.150/modPages/pirellis.html
Hope that helps
Old Jan 11, 2003 | 06:38 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Yeah but RE010's are almost $150 for EACH tire.
Old Jan 11, 2003 | 06:40 PM
uNF$@#!'s Avatar
yeah, trade off is a bitch.
heck i wouldnt know what i'd do in your position, as you need to factor in the installation of the tires on the wheels a cost to consider as well.
Old Jan 11, 2003 | 06:41 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
I might just stick with my SO-3's which kick major butt for a street tire.
[Modified by ActiveAero, 9:41 PM 1/11/2003]
Old Jan 11, 2003 | 06:46 PM
migs's Avatar
ActiveAero, the Pirelli's are great tires but there are other similiar costing alternatives out there like your S03's. Those Pirelli's are often found on the later Jaguar's. They are putting down anywhere from 10000-13000 miles
For the money, Id get S03's. Why are alot of ITR's running 195-50-15? Isnt that too small for the car?
Old Jan 11, 2003 | 06:50 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Pirelli PZero Assimetrico? (Migs)
Not unless you are riding around with 4 people taking corners hard. They also feel less sloppy than 205's and raise the final drive slightly. I've been through 3 sets of 195/50 SO-3's so far with no problems. 10,000-13,000mi is all I get out of my SO-3's anyway. I'm fixing to be on my 6th set of tires in only 55,000mi with no track events.
Old Jan 11, 2003 | 06:58 PM
migs's Avatar
I have Kuhmo 712's and they have 6/32" left at approx 14K!
Old Jan 11, 2003 | 07:01 PM
Dirt's Avatar
Worthless statement. It depends what you use them for. 5000 miles on track days, sure, but solely on the street, you'll see 20,000 miles or more with proper rotation.
https://honda-tech.com/zerothread?id=313546
I posted this when I got my PZeros from Tire Rack back in October. Tire Rack won't sell them to you if you say they are used for the R.
[Modified by BrewCityR, 10:02 PM 1/11/2003]
Old Jan 11, 2003 | 07:05 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Pirelli PZero Assimetrico? (BrewCityR)
Yeah I already know this thats why I call in and order 4 tires for my kid's (which I don't have) tire swing.
By the way I will still use my SO-3's on the street. I just wanted a decent peforming track tire that I can learn on and won't cost me a fortune to replace.
[Modified by ActiveAero, 10:06 PM 1/11/2003]
Old Jan 11, 2003 | 07:07 PM
uNF$@#!'s Avatar
are you on crack? how about not talking out of your *** prior to stating you'd get 20k + miles with 125 treadwear tires....
Old Jan 11, 2003 | 07:12 PM
Dirt's Avatar
140 treadwear, Einstein. Ask Josh (itrsport.com) about his PZeros. Thank you, come again.
EDIT: Doh! Thinking about RE010s. Point being, PZeros have a higher treadwear so the wear is very similar.
[Modified by BrewCityR, 10:16 PM 1/11/2003]
Old Jan 11, 2003 | 07:13 PM
jetydosa's Avatar
25 Year Member
According to Tirerack, the PZeros have a treadwear of 140, and the RE010s have a treadwear of 120.
Old Jan 11, 2003 | 07:15 PM
jetydosa's Avatar
25 Year Member
Why is that?
Old Jan 11, 2003 | 07:18 PM
Dirt's Avatar
Default Re: Pirelli PZero Assimetrico? (Jetydosa)
Load rating isn't what a 195/55 or 205/50 is.
Old Jan 11, 2003 | 07:26 PM
migs's Avatar
Load rating on 195-55-15 are normally 89H or 89V or 89W
The Number is the LOAD rating. The Letter is the SPEED Rating.
Soup ****, I will admit, you are ABSOLUTELY INCORRECT. Treadwear does not JUSTIFY its longivity. Its a common belief that it is, but its a common stupid misunderstanding of tires. Treadwear only tells how SOFT the compound is. Doesnt determine life.
I have 89W rated tires and like I said, I have nearly 15K on the tires and they are at 6/32" of an inch in depth!! I can see about 30K miles on these tires!!
BrewcityR is correct, proper rotation, balance, and alignment are EXTREMELY important to saving your tires. Alot of people overlook this service.
--migs
Old Jan 11, 2003 | 07:28 PM
migs's Avatar
Why is that?
Technically, the load rating of the 195-50-15 tire is not capable to with stand the weight of the ITR. The 195-50-15 is only qualified to hold so much, however doesnt mean it wont HOLD it, just means its not "certified" for it. Make sense?
Old Jan 11, 2003 | 07:32 PM
itrsport.com's Avatar
The PZero's have been an excellent tire for me. I used them for about 33,000 miles and really like how the perform. I'm running 205/45/16's on my Volks. I paid a tad over $100 per tire on tirerack.
The tires experienced 6 one minute passes at a local AutoX and the rest was daily driving for me. I'll probably pick up another set in the spring.
Old Jan 11, 2003 | 08:44 PM
Buckshot's Avatar
Default Re: Pirelli PZero Assimetrico? (itrsport.com)
im sure they are a bad *** tire..well at least a few years ago they were..on all the high end tuner cars that seemed to be the tire of choice...but like i said that was a few years ago, im sure there are better tires out now.
but for 50 bux you mine as well get them, im sure u wont be dissapointed
Old Jan 11, 2003 | 09:27 PM
danelot's Avatar
Is it still safe to use these tires dispite the the load rating? I'm thinking of buying so3's in this size. I don't plan on tracking my car, but I do like to hit the back roads hard.
Old Jan 12, 2003 | 10:23 AM
Misfit's Avatar
Default Re: Pirelli PZero Assimetrico? (danelot)
I use 195 50's on the R. i told tire rack that these tires were never going to see the street. just auto cross and such. they sold them to me. they are Yokoham avs es100.
Old Jan 12, 2003 | 01:08 PM
2001TypeR's Avatar
Falken Azenis Sports ownz j00....good for drag, good for track, good for street, good for everything lol
