Question, Is it worth of swapping full LSD tranmission and throw out automatic LS?
I have thought countless hours about the tranmission swap.
The automatic tranmission need to go now.
I need a good shops in nova to do this.
How much am I looking at the cost?
I have 1998 LS automatic coupe.
Thank you.
[Modified by CrazyHondaBoy, 2:47 AM 1/12/2003]
Thank you.
if your going with a manual tranny may as well use a GS-r tranny with will run 800-1000 if u want a LSD another 800...........plus install
also may as well get a new clutch with will be 300-400 maybe a good flywheel for 200 (i may be wrong on that)
LSD install i would not do myself but the tranny is simple and could be done by u and some friends with some car knowledge
u also need a new comp($100) and the pedals i think
you also need the clutch master cylinder, shift linkage, and shifter and in my eg i needed a special tranny mount because the automatic mount is diffrent from the manual i dont know if this is the same on integras dont forget teh wiring of teh reverse lights also
apron8
May 29, 2003 06:03 PM
I'll keep you guy update.
