OBD1 H22A timing questions
Old Jan 11, 2003 | 08:13 AM
3gLudeH22A's Avatar
Default OBD1 H22A timing questions
Now i know that the stock timing is set at 15 degrees (i dont even know what mine is set at) But heres what i wanted to know
1. Does the ECU adjust timing at warmup??
2. Does it change depending on driving conditions???
Reason im asking is because a buddy of mine told me that h22 ecu changes timing by itself...Im just checking because i thought that the only way to change timing was to do it manually.
Old Jan 11, 2003 | 10:33 AM
Fly1865's Avatar
Default Re: OBD1 H22A timing questions (3gLudeH22A)
all you do is rev the engine up until the coolings fans kick on then you can check the timing
Old Jan 11, 2003 | 11:35 AM
sslude's Avatar
Default Re: OBD1 H22A timing questions (Fly1865)
yeah, some people (like myself) tried to move the distributor a tiny bit to advance timing, but it doesnt budge. i think the ECU controls timing, correct me if i am wrong though.
Old Jan 11, 2003 | 06:22 PM
DirtyLude's Avatar
Default Re: OBD1 H22A timing questions (sslude)
If you jump the service connector before starting the car it lock the timing so you can adjust it correctly. Yes, otherwise the timing is variable.
Old Jan 11, 2003 | 06:30 PM
qwklude82's Avatar
Default Re: OBD1 H22A timing questions (DirtyLude)
so the cooling fans have to kick on before you can check the timing?
Old Jan 11, 2003 | 06:58 PM
3gLudeH22A's Avatar
Default Re: OBD1 H22A timing questions (qwklude82)
Im thinking what he means by that is basically wait untill the car has reached its proper operation temperature (heat cycle is what i think its called)
djnikko
Jan 12, 2010 02:50 PM
kixcrx
Nov 10, 2006 10:33 AM
Nextelbuddy
Mar 30, 2004 10:09 AM
tampaSi
Aug 16, 2001 04:16 PM
