Stay obd0 or go obd1?
Old Jan 11, 2003 | 08:01 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Stay obd0 or go obd1?
Im putting a b18a into my 90 crx and i was wondering if i should stay non obd or if i should go obd1? Im putting this engine in for the sole purpose of boosting it. Ive heard that its better to go obd1 if youre going turbo for some reason....i think it has something to do with hondata? I know that there is a guy on here running hondata with a non obd car so im a litte confused. What are the pros and cons of non obd and obd1? Why is it better to go obd1 for hondata?
Also, can someone on here post a link to a wiring diagram for the obd0 to obd1 conversion? Thanks
Sean
Old Jan 11, 2003 | 09:04 AM
true's Avatar
Default Re: Stay obd0 or go obd1? (sCeRaXn)
Convert to obd1. There are many threads on the pros/cons...try a search. Here is the pinout:
http://www.boosted.org/ecu/COMPLETE.txt
Old Jan 11, 2003 | 12:57 PM
CRVRX's Avatar
Default Re: Stay obd0 or go obd1? (true)
Why not run a Zdyne in there ? , It will plug right in, You will be able to run up to 28 lbs of boost and it is very user friendly. I have tune many cars with the Zdyne including my own and it's works very well.
[Modified by CRVRX, 9:58 PM 1/11/2003]
Old Jan 11, 2003 | 01:39 PM
sCeRaXn's Avatar
Default Re: Stay obd0 or go obd1? (CRVRX)
Thanks for the replys...but what would i not be able to do if i stay non obd? Would there be any tuning problems or anything? Thanks alot.
Sean
Old Jan 11, 2003 | 07:09 PM
sCeRaXn's Avatar
I know that someone can give me a little help on this subject....
Sean
Old Jan 11, 2003 | 07:19 PM
Blaze45's Avatar
Brrraaaap!
stay non obd much easier and get a ZDYNE standalone.
Blaze
Old Jan 11, 2003 | 07:26 PM
sCeRaXn's Avatar
Default Re: Stay obd0 or go obd1? (Blaze45)
Is the Zdyne as good as Hondata...well i know its not as good but will it be ok for me. Im wanting a streetable car that will hav around 250-280hp MAX. is it as easily tunable as the hondata? Thanks for the reply.
Sean
Old Jan 12, 2003 | 07:16 AM
sCeRaXn's Avatar
t T t. . . .
Old Jan 12, 2003 | 08:49 AM
RAWB's Avatar
Sean
The drawback on ZDYNE vs Hondata is that Zdyne does NOT datalog. However, the Zdyne is still a great unit, do a search for "ZDYNE" and read some of the threads by people who are running it. It comes with a really good base program and you can tune it on the fly without needing someone with tuning software(Hondata 4B, for example) or an emulator. GL.
zamrioo2
Oct 2, 2007 12:38 AM
crxtech
Mar 30, 2006 06:44 AM
EF9-G'zer
Jun 27, 2004 08:38 PM
rice4life
Jul 25, 2002 01:59 PM
